7298 Discussions
libmkl_gnu_thread.so can't find symbol... and neither do I
puch
I got tasked to recompile some existing software that depend on MKL. The first think I did was setting-up a test machine to avoid messing up my development box. I installed Fedora14, the gcc compiler, MKL and all the other required libraries necessary to emulate our work environment. Then I made a make file and compiled. Everything worked as expected.
Then I proceeded to replicate the setting on the machines we use in the office. They have Fedora14 and I managed to install all the libraries that I needed and I used on the test box. Copied over the make file, shell environment etc.
When I compile the code on the new machine I get:
/mkl/lib/intel64/libmkl_gnu_thread.so: undefined symbol: mkl_blas_xsgemm0_brc
Everything I have checked seems to be identical to the test box except of course for the fact that on the test machine I have installed Fedora14 from scratch and on the "real" machine Fedora14 was already there.
I have googled the error message but I couldn't find anything
Can somebody here point me in the right direction?
Thank you!
Gennady_F_Intel
interesting, how it would be... you can checklist the symbols being exported from this so.
or just try to use *_intel_thread.so instead this one.
