mkl_ddiamv multi-thread support
Aaron_B_1
Does mkl_ddiamv support multi-thread calculation?
In my project's properties I set "Use Intel MKL" to "Parallel". The majority of time of my programm is matrix-vector multiplication, which is performed by mkl_ddiamv. In my task manager I always see, that ONLY ONE thread is busy by my programm process. I use Intel C++ Compiler 14.0. I try to take many different sizes of multiplicated arrays. There is no difference. I unsuccessfully tried to find some info about the reason of one-thread calculation.
Is it normal behavior of this function or I do something wrong? Should I change some of my project's properties or include something to launch my app multi-threated?
Gennady_F_Intel
this function is single-threaded until the latest version. You may try make the conversion to CSR format and try mkl_csrmv routines.
