7298 Discussions
mkl_rci.fi (nonlinear least squares) single precision
mpiuser
According to the reference both the single and double precision versions of the nonlinear least squares solver routines can be accessed by including mkl_rci.fi . But, from what I can tell this file only references the double precision routines. Indeed, my program compiles and runs fine when I call the double precision versions, but I cannot compile the single precision version because the routines are apparently not found.
What am I missing here?
Alexander_K_Intel2
What version of MKL do you use?
With best regards,
Alexander Kalinkin
Gennady_F_Intel
the single precision support has been added since the 10.3 version.
mecej4
When you do succeed in building the single precision version program, do not expect the example program supplied with the MKL distribution to work unmodified. In particular, when you approximate derivatives using numerical differentiation, you should make the convergence criteria less stringent.
