7302 Discussions
numerical integrator dodesol_mk52lfn and tolerance
Brian_Murphy
New Contributor II
I am using dodesol_mk52lfn as a replacement for the Gear numerical integrator in the IMSL.  dodesol_mk52lfn has a tolerance input argument, ep, which I do not understand.  dodesol_mk52lfn output matches IMSL quite well with ep on the order of 0.1 to 1.0, whereas it seems that this argument ought to be on the order of 1e-6.  For instance, the example problem in the documentation uses ep=1e-6 and says this produces accuracy of "about 5%".
ep DOUBLE PRECISION
(input) Relative error tolerance, which must be small enough. The code cannot ensure the requested accuracy for ep<1.d-9. This parameter is used to control the step size.
Brian Murphy
Gennady_F_Intel
Brian, may be would be better to post such question to the imsl forum? https://forums.roguewave.com/forumdisplay.php?110-IMSL-Numerical-Libraries.
Brian_Murphy
New Contributor II
But my question is about the MKL routine, not about the IMSL routine.  I need help with the MKL routine.  What the documentation says about the "relative error tolerance" is not consistent with the results I get using the routine.  Is it possible the "relative error" is defined in a non-standard way?
