pardiso_schur.c with MKL_PARDISO
bopeng
I am using 2021.04 oneAPI release.
/opt/intel/oneapi/mkl/latest/examples/c/sparse_directsolvers/source/pardiso_schur.c
currently the setting are:
MKL_INT perm[8] = {0, 0, 0, 0, 0, 0, 1, 1};
It assumes the last two row and col 2x2 will be think as A22.
If I change that to
    MKL_INT perm[8] = {1, 1, 0, 0, 0, 0, 0, 0};
I thought it will do reordering for me, but after change that, the calculated results are wrong.
Can you point out what's wrong?
@Kirill_V_Intel
I am an employee of Intel, ping me directly if any need.
Thanks so much!
The reason I am doing this:
My own matrix is
    A11=1482x1482, A22=78281x78381
If I want to reuse this pardiso_schur.c, S=A22-A21 * A11-1 * A12 will be 78281x78281
in such situation, S*xl=bl need to solve 78281x78281, it needs huge computation time.
bopeng
Applying following patch will make it works, fixed, thanks for your support!
- MKL_INT perm[8] = {0, 0, 0, 0, 0, 0, 1, 1};
+ MKL_INT perm[8] = {1, 1, 0, 0, 0, 0, 0, 0};
MKL_INT ipiv[2];
MKL_INT n_schur = 2; /* Schur complement solution size */
@@ -191,7 +191,7 @@ int main (void)
printf("info after LAPACKE_dsytrf = " IFORMAT " \n", info);
return 1;
- info = LAPACKE_dsytrs(matrix_order,uplo,n_schur,nrhs,schur,n_schur,ipiv,&b[n-n_schur],nrhs);
+ info = LAPACKE_dsytrs(matrix_order,uplo,n_schur,nrhs,schur,n_schur,ipiv,&b[0],nrhs);
bopeng
MKL_INT ipiv[2];
return 1;
VidyalathaB_Intel
Glad to know that your issue is resolved and thanks for letting us know.
As the issue is resolved we are closing this thread. Please post a new question if you need any additional information from Intel as this thread will no longer be monitored.
Have a Nice Day!
Vidya.
