pardiso within parallel region
fah10
is it possible to call the PARDISO solver within an OpenMP
parallel region? I want to do something like
!$omp parallel
call mysubroutine(...)
!$omp end parallel
subroutine mysubroutine(...)
!$omp single
call omp_set_num_threads(nthreads)
call pardiso(...)
!$omp end single
end subroutine mysubroutine
However, within the pardiso solver, the program justs stalls when
the number of threads is greater than one. The call to omp_set_num_threads
doesn't have any effect. What can I do?
barragan_villanueva_
Valued Contributor I
Please take a look at the similar threadrelated to nested OMP parallelization
fah10
Thanks for the link.
I have successfully called omp_set_nested(.true.) to enable nesting.
However, PARDISO always stalls (at 0% cpu usage) when it's called
within an active parallel region:
call omp_set_nested(.true.)
print*,omp_get_nested() ! returns true
!$omp parallel
!$omp single
call pardiso(...) ! stalls
!$omp end single
!$omp end parallel
I also tried to start a single PARDISO thread, e.g.
!$omp parallel
!$omp single
call omp_set_num_threads(1)
!... set pardiso number of threads, iparm(3)=1
call pardiso(...)
!$omp end single
!$omp end parallel
Even this call stalls when the number of outer threads>1 just like in
the non-nested case:
call omp_set_nested(.false.)
!$omp parallel
!$omp single
!$omp end single
!$omp end parallel
Creating a thread pool of 2x the number of logical processors or invoking
KMP_BLOCKTIME as described in the other forum thread also didn't help.
Is there something special about PARDISO?
Please be sure that diferent threads use diferent ipram's because they are supposed to be private
