pdgemr2d: copy between grids
Christoph_P_2
I'd like to accomplish the following on a cluster-computer with nproc processors:
1. define two blacs grids, the first of the form p x q = nprocs, the second of the form 1 x 1, which is also just the root process
2. use pdgemr2d to copy a distributed matrix from the first grid to the second
I am already stuck at point 1.
So here are my questions:
a)  Do I have to initialize two MPI communicators and define the blacs contexts in these?
b) If not, how do I create two separate blacs contexts?
Thanks a lot in advance!
Chris
VipinKumar_E_Intel
Hi Christoph,
     I found this tut on the net, and may be helpful to your questions.
http://www.trentu.ca/academic/physics/batkinson/scalapack_docs/node11.html
 --Vipin
