problem with MKL service functions
stansy
MKL_Get_Max_Cpu_Frequency() and MKL_Get_Clocks_Frequency() can not compile using the Intel Compser XE 2011 (not included in mkl_service.h). The problem does not occur for other service functions including MKL_Get_Cpu_Frequency (). Both functions can be compiled only using VS C++.
I do not understand why
Stan
barragan_villanueva_
Valued Contributor I
Stan,
You wrote: "can not compile using the Intel Composer XE 2011 (not included in mkl_service.h)"
Pleasebe surethat MKL environment for Composer XE 2011 was set correctly using mklvars*
In mkl_service.h they are defined as follows (please check):
_Mkl_Api(double,MKL_Get_Max_Cpu_Frequency,(void)) /* get max CPU frequency in GHz */
#define mkl_get_max_cpu_frequency MKL_Get_Max_Cpu_Frequency
_Mkl_Api(double,MKL_Get_Clocks_Frequency,(void)) /* get clocks frequency in GHz */
#define mkl_get_clocks_frequency MKL_Get_Clocks_Frequency
BTW, what API do you use and for what architecture?
I mean, cdecl/stdcall IA32 or Intel64.
stansy
Hi
Many thanks Victor for your note. Theyhelped me find the right solution.
My VS2010 uses two mkl_service.hin directories: (1) ../ComposerXE-2011/mkl/include/ and (2)../ComposerXE-2001 SP1/mkl/include/.
In my environment settings first is used for Intel compiler and mkl_service.h does not contain max_cpu and clock_freq functions.
I used Intel64 and ia64 API.
Stan
