7301 Discussions
"CMake Config for oneMKL example" adapted for Fortran has "include" issues
Peter0000
I have adapted cmakelist.txt example below
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-windows-developer-guide/top/get..
for Fortran (attached), and VS2022 cannot fine F95_PRECISION etc etc
I assume $(ConfigurationName) is not wrong n the INCLUDE
C:\Program Files (x86)\Intel\oneAPI\mkl\latest\include/$(ConfigurationName)
Peter0000
The solution was simple, adding
option(ENABLE_BLAS95 "Enables BLAS Fortran95 API" ON)
option(ENABLE_LAPACK95 "Enables LAPACK Fortran95 API" ON)
to cmakelist.txt.
For the future, the attached adds other MKL options, no set to OFF.
Peter0000
I am also trying to get clues from
C:\Program Files (x86)\Intel\oneAPI\mkl\2022.1.0\examples\examples_f95\f95  but it cannot find
generate_examples_list,  setup_examples
VidyalathaB_Intel
Hi Peter,
>>but it cannot find generate_examples_list, setup_examples
Above 2 files generate_examples_list and setup_examples are located under the following path
C:\Program Files (x86)\Intel\oneAPI\mkl\2022.1.0\examples\cmake
>>cannot fine F95_PRECISION..
Maybe you can refer to the sample CMakeLists.txt given under
And if you are attempting to run the examples present in the f95 folder please make sure that the generate_examples_list and setup_examples files in cmake directory are present as mentioned in the CMakeLists.txt (like maybe you can try copying the cmake directory to the path where f95 present i.e. f95 and cmake should present in same location) otherwise you might get errors as shown below
"CMake Error at CMakeLists.txt:23 (include):
 include could not find requested file:
CMake Error at CMakeLists.txt:36 (include):
  setup_examples"
Please give it a try and do let me know if there are any issues in doing so.
Vidya.
Peter0000
Both my F95 and my smaller example seem to have a problem with with the the Additional Include Directories
which is is patched by adding
C:\Program Files (x86)\Intel\oneAPI\mkl\2022.1.0\include\intel64\ilp64
Peter0000
to cmakelist.txt.
VidyalathaB_Intel
Hi Peter,
>>The solution was simple, adding..
Glad to know that your issue is resolved and thanks for letting us know.
Please post a new question if you need any additional assistance from Intel as this thread will no longer be monitored.
Vidya.
