7303 Discussions
segmentation fault when mkl_sparse_d_mv for sparse matrix with many nonzeros
qiu__jiezhong
I am computing y=Ax (mkl_sparse_d_mv) for a 81,000 x 81,000 sparse matrix A (csr format) with 2.3*10^9 nnzs, but MKL produce segmentation fault.
The sparse matrix is dumped from another program. I first read it from disk, and then call mkl_sparse_d_create_csr to create the matrix. mkl_sparse_d_create_csr returns SPARSE_STATUS_SUCCESS. But when I move to mkl_sparse_d_mv, it shows me segmentation fault.
My another observation is that when I decrease #nnz to be 1.5*10^9, MKL can finish the computation successfully.
My hypothesis is that MKL 2.3*10^9 > 2^31, and MKL may have constraints on #nnz in a sparse matrix.
Any help would be appreciated. Thanks!
Env: Linux, parallel_studio_xe_2019_update4.
MariaZh
Hi!
Can you please try ILP64 interface for MKL?
(https://software.intel.com/en-us/mkl-linux-developer-guide-using-the-ilp64-interface-vs-lp64-interface)
I believe it may help in your case, as number of nonzero elements is indeed big.
Maria
MariaZh
Hi!
Maria
qiu__jiezhong
Zhukova, Maria (Intel) wrote:
Hi!
(https://software.intel.com/en-us/mkl-linux-developer-guide-using-the-ilp...)
Maria
Yes, it helps. Thanks a lot!!!
