some issues when building custom mkl dlls
Lane120
Hello
As the mkl library's size is too large, I want to find a way to reduce its size and then include it into my application.
I searched previous articles, and found I can try to build a custom dll following Using the Custom Dynamic-link Library Builder in the Command-line Mode (intel.com)
however, there are some issues:
1. whenever I set Parallel to intel or tbb, the result is the same
the generated mkl_custom.dll has the same size and the last link commands seem no difference
and seems always link to openmp?
2.  when I set interface to ilp64(according to LP64 interface or ILP64 interface library, which one should I link with? - Intel Community)
the library size reduced from 118MB to 85MB,  which looks like exciting to me,
however, the eigen solver with Pardiso doesn't work
(Eigen::PardisoLLT compute 's result is always 3 (Eigen::ComputationInfo::InvalidInput))
3. I use following command to build
nmake libintel64 interface=lp64 cluster=no uwd_compat=yes threading=parallel prallel=tbb export=user_example_list
and only includes following functions in user_example_list
pardiso
feastinit
dfeast_scsrev
the generated dll size still has 118MB, is there any suggestion to reduce more dll size?
thanks very much
JilaniS_Intel
Thanks for posting in Intel communities.
We tried to generate the custom dll at our end, and we are getting the following results.
command : nmake libintel64 interface=lp64 cluster=no uwd_compat=yes threading=parallel prallel=tbb export=user_example_list
Interface = lp64
Functions : pardiso, feastinit , dfeast_scsrev
Custom DLL size : 115 MB
command : nmake libintel64 interface=ilp64 cluster=no uwd_compat=yes threading=parallel prallel=tbb export=user_example_list
interface = ilp64
Custom DLL size : 83 MB
>>  when I set interface to ilp64  the library size reduced from 118MB to 85MB,  which looks like exciting to me,
Could you please provide us a sample reproducer and OS details, so that we can replicate and investigate more at our end.
Jilani
JilaniS_Intel
Hi ,
Sorry for the late and edit reply.
The size of the custom DLL is 115 MB as expected for the interface=lp64.
The information would be helpful to understanding of the issue deeply.
Jilani
JilaniS_Intel
A gentle reminder:
Could you kindly share a sample reproducer along with the details of the OS? This will enable us to replicate and conduct a more thorough investigation on our end.
Jilani
JilaniS_Intel
A gentle reminder:
Jilani
