7302 Discussions
status = DftiSetValue( pHandle, DFTI_PACKED_FORMAT, DFTI_CCS_FORMAT);
Erich_Zwyssig
Hello all
Am I right in assuming that the good ault dzfft1d used the CCS format (by default) and the new Dfti procedures use Pack (by default)?
Therefore
- status = DftiSetValue( pHandle, DFTI_PACKED_FORMAT, DFTI_CCS_FORMAT);
should get me the same DFT output in Dfti as in dzfft1d?
Do I set the CCS format before or after DftiCommitDescriptor?
I tried before but cannot see a change in the DFT output.
Any advice?
Thanks for your help
Erich
Dmitry_B_Intel
Erich,
For 1D real-to-complex transform, DFTI assumes CCS storage as the default, the same as dzfft1d did. That is probably why you don't see a change in the output when you correctly set it before DftiCommitDescriptor.
Dima
Erich_Zwyssig
Hi Dima
Thank you for your reply.
If that is the case, then I'd expect to see 0's in the data, i.e. in position '(0).im', but I don't.
Any idea what's wrong?
Erich
Dmitry_B_Intel
Erich,
This looks like a weird bug. Could you share how do the transform,what floating point precision, what language, what MKL version do you use, what platform, what is compile/link line?
Dima
Erich_Zwyssig
Hi Dima
MKL 10.2.2.025
Linux 2.6.18-164.15.1.el5.inf.1PAE #1 SMP Tue Apr 27 10:03:58 BST 2010 i686 i686 i386 GNU/Linux
C++
then
MKL_LONG status;
status = DftiCreateDescriptor( &pHandle, DFTI_DOUBLE, DFTI_COMPLEX, 1, L);
status = DftiCommitDescriptor( pHandle);
later
status = DftiComputeForward( pHandle, x_fft );
for compile and link I got a makefile. Are you interested in anything special? I'd rather not share the complete file, sorry.
Erich
barragan_villanueva_
Valued Contributor I
Hi Erich,
For real-to-complex transform you need to use
status = DftiCreateDescriptor( &pHandle, DFTI_DOUBLE, DFTI_REAL, 1, L);
Please take a look at $MKLROOT/examples/dftc/source/real_1d_ccs_double_ex*.c for more details.
Also, CCS format is by default for such transforms.
Erich_Zwyssig
Hi Victor
Thanks for your help.
Question, what does the order of FFT, iFFT, setting the DFTI_BACKWARD_SCALE factor and
committing need to be?
status = DftiSetValue( pHandle, DFTI_BACKWARD_SCALE, Scale);
Can I set all values, then commit, i.e.
- create
- set #1 (format)
- set #2 (backward scale)
- commit
- run loads of FFTs
- run loads of iFFTs
or do
- set (backward scale)
- commit
need to be done after the FFT, right before the iFFT?
Kind regards
Erich
Hi Erich,
The most correct way is
- create
- set all values you want (no commits are needed during settings)
- commit at last
and use FFTs or iFFTs.
But if you want to change some value again than commit will be required.
Erich_Zwyssig
Hi Victor
Thanks for your reply.
It all seems to work fine now.
One final question. Would you expect to get the exact same values from mkl_crfft1d and DftiComputeBackward if Scale = 1.0/(double)n; is used?
Kind regards
Erich
Erich
All DFTI transforms are not normalized and therefore you can use/(or not) scaling if needed.
For example,for 1D with using scaling=1/n you will get approximately the same (not exacltly the same) results after forwardplus backward transforms.
