threads of mkl
vadim_l
I have a question for the library mkl
I have intel core i3 with 4 logical cores, and was installed Parallel Studio 2011 and the intel composer XE 2011 with version mkl 10.3.1. When I create a project in visual studio I chose the menu option - 'parallel' mkl in composer ,but when the program was started, windows task manager show only 2 working cores, what's the problem?
I tried using the function mkl_set_num_threads(4),but nothing changed.
barragan_villanueva_
Valued Contributor I
Maybe it's because MKL recognizes HT and limits threads to 1 per core by default to get the best performance.
To allow using all logical cores please set environment MKL_DYNAMIC=false together with settting MKL_NUM_THREADS=4 or using the function mkl_set_num_threads(4).
vadim_l
Thanx, Victor,
the function mkl_set_num_threads(4) together with omp_set_dynamic(false) helped me. However, the performance is no much increased.
Tell me please on how many physical cores MKL shows significant performance?
Quoting vadim_l
In general it depends on MKL domain and tasks you are using. For BLAS for example the best performance will be when used 1-cpu for core (similar toHT is off).
But for other parts you can get some improvements in using HT.
