trouble when running the fft examples
Peter_Petropoulos
As the subject says. I have sourced the intel64 .sh file...libiomp5.dyld is in /opt/intel/Compiler/11.1/088/lib
I'm stumped (as usual!).
Here's what I get in directory /opt/intel/Compiler/11.1/088/Frameworks/mkl/examples/fftw3xf
bash-3.2$ make libem64t interface=ilp64
make lib _IA=em64t
rm -rf ./_results/intel_ilp64_parallel_em64t
test -d ./_results/intel_ilp64_parallel_em64t || mkdir -p ./_results/intel_ilp64_parallel_em64t
ifort -vec-report0 -i8 -I../../include/fftw -c source/mkl_fftw_examples_support.f -o _results/intel_ilp64_parallel_em64t/mkl_fftw_examples_support.o
ifort -vec-report0 -i8 -I../../include/fftw source/complex_1d_double_ex1.f _results/intel_ilp64_parallel_em64t/mkl_fftw_examples_support.o -L../../lib/em64t -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -o _results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.out
DYLD_LIBRARY_PATH="../../lib/em64t:$DYLD_LIBRARY_PATH" _results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.out >_results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.res
dyld: Library not loaded: libiomp5.dylib
Referenced from: /opt/intel/Compiler/11.1/088/Frameworks/mkl/examples/fftw3xf/_results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.out
Reason: image not found
/bin/sh: line 1: 721 Trace/BPT trap DYLD_LIBRARY_PATH="../../lib/em64t:$DYLD_LIBRARY_PATH" _results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.out > _results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.res
make[1]: *** [_results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.res] Error 133
rm _results/intel_ilp64_parallel_em64t/mkl_fftw_examples_support.o
make: *** [libem64t] Error 2
bash-3.2$
Thanks for setting me straight.
barragan_villanueva_
Valued Contributor I
It's strange because libiomp5.dylib (together with all MKL-libraries) should be located in the
/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t
directory
Artem_V_Intel
It's wrong. libiomp5.dylib is located in the/opt/intel/Compiler/11.1/088/lib as Peter mentioned, because only Professional Compiler distribution exist under Mac OS X operating system.
Artem
Artem_V_Intel
Hello Peter,
I tried to follow your steps and doesn't obtain any issues. Please see the log of my actions below:
# bash
bash-3.2# source /opt/intel/Compiler/11.1/088/bin/ifortvars.sh intel64
bash-3.2# make libem64t interface=ilp64
make lib _IA=em64t
ifort -vec-report0 -i8 -I/opt/intel/Compiler/11.1/088/Frameworks/mkl/include/fftw -c source/mkl_fftw_examples_support.f -o _results/intel_ilp64_parallel_em64t/mkl_fftw_examples_support.o
ifort -vec-report0 -i8 -I/opt/intel/Compiler/11.1/088/Frameworks/mkl/include/fftw source/complex_1d_double_ex1.f _results/intel_ilp64_parallel_em64t/mkl_fftw_examples_support.o -L/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -o _results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.out
DYLD_LIBRARY_PATH="/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t:$DYLD_LIBRARY_PATH" _results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.out >_results/intel_ilp64_parallel_em64t/complex_1d_double_ex1.res
etc etc...
Did you change environment after sourcing ifortvars.sh?
May be your installation of Intel Fortran Compiler is broken. Try to reinstall it.
Artem
Well, according to the following used path -L../../lib/em64t it means that MKLROOT was not set before run examples
Peter_Petropoulos
Thanks for the replies guys...I must hang my head in shame !
I was trying the examples under opt and was sourcing the environment script as me and then
using sudo to do the make...DUH!
