undefined symbol: mkl_dft_xc_4step_scale_4
utab
Hi all,
I was trying to compile UMFPACK with intel mkl blas and intel mkl lapack so I used the command line options for the UMFPACK BLAS and LAPACK definitions as given by the link advisor like.
-L/home/utabak/intel/composerxe-2011/mkl/lib/intel64/ -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread
Now the problem is that it compiles and links fine however I get a
./umfpack_simple: symbol lookup error: /home/utabak/intel/composerxe-2011/mkl/lib/intel64/libmkl_sequential.so: undefined symbol: mkl_dft_xc_4step_scale_4
from the simple umfpack example. So I was using GotoBlas on my local laptop to do this. But on the linux cluster, I could not compile goto and gave a intel mkl a try and got this error. Basically what I try to do is to use blas and lapack of the mkl library, what should be the workaround?
Umut
Dmitry_B_Intel
Hi Umut,
Probably a mix of different versions of MKL is present in the environment, which makes the loader to complaint on a symbol not found in previous versioin of the shared library. You could see the loader traces byrunning the program as follows:
LD_DEBUG=symbols ./umfpack_simple
or
LD_DEBUG=all ./umfpack_simple
Dima
