using MKL in place of CSparse library
meinyahanhoongmail_c
I've been working on a code where I want to implement MKL instead of CSparse library. Just for the reference, CSparse function routines can be seen on " http://www.cise.ufl.edu/research/sparse/CSparse/ ". I am finding trouble in handling the cs_multiply and cs_add functions. Also, the CSparse library has defines a structure " cs* " for storing and using sparse matrices, but for using MKL functions, one has to pass all the details manually every time. Please suggest some way to proceed ahead.
Also, which function of MKL can be used to multiply 2 sparse matrices? The function I found in MKL for solving C=A*B (A,B,C all are matrices) are for one sparse matrix and the rest are dense matrices.
Please look through this and help me out.
Regards..... :)
ArturGuzik
Valued Contributor I
Regards..... :)
I replied in the other (copy) of this thread.
A.
