7299 Discussions
vdSqr function seems not to return correct answer on Xeon Gold 6132
Kurokawa__Hiroshi
(Sorry for my poor English, I'm not a native.)
vdSqrt function of MKL returns incorrect answer if I used this function under my developement environment.
Here is my environment.
OS:Windows 10 x64 Pro
CPU: Xeon Gold 6132 * 2
Mem:288GB
DevTools: Visual Studio 2017 (using MS C/C++ compiler , not Intel's C)+ MKL 2018 Upd1(AcademicResearch free License)
Here is short reproduction code,
#include "stdafx.h"
#include <vector>
#include <mkl.h>
int main()
 std::vector<double> Source, Normal, MKL;
 size_t Size = 10000;
 Source.resize(Size);
 Normal.resize(Size);
 MKL.resize(Size);
 // create calc. target source 1, 2, 3, .....
 for(auto i = 0; i < Size; i++)
  Source = i + 1;
 // Exec std::sqrt to all target
  Normal = std::sqrt(Source);
 // Exec vdSqr to all target
 vdSqr((int)Size, Source.data(), MKL.data());
  if(std::abs(Normal - MKL) > 0.0001)
   printf("No = %d, Val:%f Normal:%f MKL:%f\n", i, Source, Normal, MKL);
   throw std::runtime_error("mismatch!");
 return 0;
normal std::sqrt function returns 1, 1.4142, 1.732, .....
but MKL vdSqrt function returns 1, 4, 9, 16, .......
Sincerely,
Gennady_F_Intel
pls try to use vdSqrtnay );
Kurokawa__Hiroshi
I'm sorry for taking your time for my easy careless mistake.
I confirmed the correct result in the way you taught.
Thank you for your help.
