7287 Discussions
warnings and remarks from MKL, what is the reason?
utab
Dear all,
I am testing the MUMPS Fortran 90 interface for some simple block right hand side solution however I get a buch of warnings and remarks. These are all related to spblas, lapack, rci interfaces.
What could be the reason of these warnings and remarks? Attached file is an example of the output of the make process. You can examine the compile flags and direct me as necessary.
Umut
mecej4
Many of the Fortran include files (*.fi) supplied with MKL are not intended to be compiled with /warn:all and similar options. To silence the warnings related to the contents of the include files, while still receiving warnings related to your code, surround the INCLUDE statements in your code with the compiler directives shown below, for fixed-format source files:
cDIR$ NODECLARE
        INCLUDE "mkl_rci.fi"
cDIR$ DECLARE
In free format source files, change "cDIR" to "!DIR".
If you wish to speed up the compilation process, instead of using INCLUDE statements in your code, create modules that do the INCLUDE, and USE the modules in your source code.
utab
cDIR$ NODECLARE
cDIR$ DECLARE
Actually, I am only including mkl.fi and the includes in the log file are automatically included. However your suggestion did not help me. What I did as you have suggested is
!DIR$ NODECLARE
include 'mkl.fi'
!DIR$ DECLARE
for free source format.
Umut
