Intel oneAPI Registration
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
408 Discussions
OneAPI Integration with Visual Studio 2019
Ahmadi__Afshin
I am trying to install OneAPI Base Toolkit 2021.3 on an offline computer with VS2019 and Windows Server 2019, but the installer cannot detect Visual Studio. I checked other related posts on this forum, but neither provides a working solution.
I was able to successfully install this toolkit on another computer with the same VS version. The only difference is that this machine is connected to the internet, VS is installed on C:\ drive, and the operating system is Windows 10.
Any suggestion on how to resolve this issue? You can find all the information that you need in the below screenshots.
Afshin
Soumya_M_Intel
Hi Ahmadi__Afshin,
Thanks for posting your concern on the forum. Please let us know the below details.
  • A copy of the 'About' (by using the 'Copy Info' option) from the Help section, of the Visual Studio.
  • Is the directory location of Intel® oneAPI Base Toolkit also within the D drive? Please provide the path.
  • The screenshots of all the stages from the installation process of the Intel® oneAPI Base Toolkit.
The above information would provide us a better understanding of the concern.
Soumya
Ahmadi__Afshin
Hi Soumya,
Thanks for getting back to me. Please find the requested information below.
1. Visual Studio information:
Microsoft Visual Studio Professional 2019
Version 16.10.1
VisualStudio.16.Release/16.10.1+31402.337
Microsoft .NET Framework
Version 4.7.03190
Installed Version: Professional
Visual C++ 2019 00435-30013-37913-AA320
Microsoft Visual C++ 2019
ASP.NET and Web Tools 2019 16.10.526.50910
Azure App Service Tools v3.0.0 16.10.526.50910
C# Tools 3.10.0-4.21269.26+029847714208ebe49668667c60ea5b0a294e0fcb
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools 1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Extensibility Message Bus 1.2.6 (master@34d6af2)
Provides common messaging-based MEF services for loosely coupled Visual Studio extension components communication and integration.
IntelliCode Extension 1.0
IntelliCode Visual Studio Extension Detailed Info
Linux Core Dump Debugging 1.0.9.31313
Enables debugging of Linux core dumps.
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft MI-Based Debugger 1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards 1.0
Microsoft Visual Studio VC Package 1.0
Mono Debugging for Visual Studio 16.10.15 (552afdf)
Support for debugging Mono processes with Visual Studio.
NuGet Package Manager 5.10.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension 1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
TypeScript Tools 16.0.30429.2002
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 3.10.0-4.21269.26+029847714208ebe49668667c60ea5b0a294e0fcb
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual C++ for Linux Development 1.0.9.31313
Visual F# Tools 16.10.0-beta.21262.7+1b23bbeda88ea3cb9be9af777f4c99fa8663df81
Microsoft Visual F# Tools
Visual Studio Code Debug Adapter Host Package 1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Tools for CMake 1.0
VisualStudio.DeviceLog 1.0
Information about my package
VisualStudio.Foo 1.0
VisualStudio.Mac 1.0
Mac Extension for Visual Studio
Xamarin 16.10.000.230 (d16-10@0e66389)
Visual Studio extension to enable development for Xamarin.iOS and Xamarin.Android.
Xamarin Designer 16.10.0.115 (remotes/origin/c750fbf1bde3c720d077f51640fe197c6dac7cbe@c750fbf1b)
Visual Studio extension to enable Xamarin Designer tools in Visual Studio.
Xamarin Templates 16.10.5 (355b57a)
Templates for building iOS, Android, and Windows apps with Xamarin and Xamarin.Forms.
Xamarin.Android SDK 11.3.0.1 (d16-10/22fc2b3)
Xamarin.Android Reference Assemblies and MSBuild support.
Mono: b4a3858
Java.Interop: xamarin/java.interop/d16-10@f39db25
ProGuard: Guardsquare/proguard/v7.0.1@912d149
SQLite: xamarin/sqlite/3.35.4@85460d3
Xamarin.Android Tools: xamarin/xamarin-android-tools/d16-10@c5732a0
Xamarin.iOS and Xamarin.Mac SDK 14.20.0.3 (17fdcf569)
Xamarin.iOS and Xamarin.Mac Reference Assemblies and MSBuild support.
2. If you are asking about the location of the OneAPI installer, I run it from D:\ drive and extract the files to D:\intel_temp\w_BaseKit_p_2021.3.0.3221_offline. I have tried installing in both C:\Program Files (x86)\Intel and D:\Program Files (x86)\Intel.
3. Here are the screenshots:
I really appreciate it if you can provide a workaround.
Afshin
Soumya_M_Intel
Hi Ahmadi__Afshin,
Thanks for providing the information. We are checking on it with our internal team. Please wait for 2-3 business days. We will get back to you as soon as possible.
Soumya
Devorah_H_Intel
Please do the following - download the latest 2021.4 oneAPI package that was just released today. Then:
1. Repair Visual Studio
2. Run the oneAPI 2021.4 Installer
Let me know if this helps.
Ahmadi__Afshin
I followed your instructions but it didn't fix the issue. Anything else I can do? Thanks.
Devorah_H_Intel
I can only suggest to completely reinstall VS and then run the oneAPI installer.
In some cases the VS Repair is sufficient, in other cases one needs to run the VS installer again to make sure that it is registered correctly in the system.
