Intel oneAPI Registration
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
402 Discussions
OneAPI windows install with silent option
Zukaitis__Anthony
Does the silent option still work?
This still fails in my windows docker container and appears to still bring up a gui when running by hand.
RUN w_BaseKit_p_2021.3.0.3221.exe -s -a --silent --eula accept
ArpanB_Intel
Anthony, we tested out the silent installation ourselves.
We were not able to replicate your issue and the silent installation was successful on Windows for Intel® oneAPI Base Toolkit on our end. Please confirm whether your toolkit is a local installer(offline) or an online toolkit(size in few megabytes). Also, check whether your system is meeting the prerequisites set for the product from the link we had shared earlier with you.
ArpanB_Intel
Hi Anthony, please follow the below steps for a non-interactive installation:
  • Go to the directory first where the installer is located
  • Run the following command:
w_[Toolkit Name]Kit_[version]_offline.exe -s -a --silent --eula accept
  • Once the installation is complete, verify that the toolkit is installed in the default directory: C:\Program Files (x86)\Intel\oneAPI
If you are using Intel GPU, you will need to install the GPU drivers separately.
Zukaitis__Anthony
I tried with the offline installer per your instructions and get the following error:
cmd /S /C w_BaseKit_p_2021.3.0.3221_offline.exe -s -a --silent --eula accept' returned a non-zero code: 1001
ArpanB_Intel
Anthony, could you confirm whether your system matches the prerequisites on Windows, Please click here: https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-onea..., to verify. Meanwhile, we will test this issue out ourselves and share our findings.
ArpanB_Intel
