As the title says, oneAPI Base Toolkit 2021.4 fails to ingegrate with VS2017 on Windows 11.
Log:
11/20/2021 23:20:59:761 : 12036 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/mulde/AppData/Local/Temp/intel_oneapi_installer/2021.11.20.23.20.55.773 --product-id intel.oneapi.win.basekit.product --product-ver 2021.4.0-3421 --package-path H:\w_BaseKit_p_2021.4.0.3421_offline\packages
11/20/2021 23:20:59:761 : 12036 : MESSAGE : Installer is started in GUI mode
11/20/2021 23:20:59:761 : 12036 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.0.9.0-678
11/20/2021 23:20:59:761 : 12036 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.0.5-217
11/20/2021 23:20:59:761 : 12036 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2021.4.0-3421. Mode is set to install.
11/20/2021 23:21:00:295 : 16516 : MESSAGE : PreRequisite for other install successfully checked
11/20/2021 23:21:00:297 : 16516 : MESSAGE : PreRequisite for other Intel install successfully checked
11/20/2021 23:21:00:300 : 16516 : MESSAGE : All checks for preRequisite for supported operation system are passed
11/20/2021 23:21:00:551 : 16516 : MESSAGE : PreRequisite for temporary folder successfully checked
11/20/2021 23:21:00:551 : 16516 : MESSAGE : PreRequisite for host architecture successfully checked
11/20/2021 23:21:12:404 : 9912 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
11/20/2021 23:21:12:404 : 9912 : MESSAGE : Error [Intel® Graphics Driver for Windows not found.]
11/20/2021 23:21:12:404 : 9912 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
11/20/2021 23:21:23:158 : 9912 : MESSAGE : PreRequisite for free disk space passed
11/20/2021 23:21:23:160 : 9912 : MESSAGE : PreRequisite for permissions passed
11/20/2021 23:21:23:160 : 9912 : MESSAGE : PreRequisite for other install successfully checked
11/20/2021 23:21:23:160 : 9912 : MESSAGE : PreRequisite for other Intel install successfully checked
11/20/2021 23:21:23:184 : 9912 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2017] passed
11/20/2021 23:21:23:184 : 9912 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
11/20/2021 23:21:23:202 : 9912 : MESSAGE : Check for blocking processes passed
11/20/2021 23:21:23:220 : 9912 : MESSAGE : Check for blocking processes passed
11/20/2021 23:21:23:309 : 12036 : MESSAGE : ISIP consent status is 'No'
11/20/2021 23:21:23:309 : 12036 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
11/20/2021 23:21:23:309 : 12036 : MESSAGE : Product installation size required: 30667140914 bytes
11/20/2021 23:21:23:309 : 12036 : MESSAGE : Product will be (un)integrated with the following IDEs:
11/20/2021 23:21:23:309 : 12036 : MESSAGE : Microsoft Visual Studio* 2017
11/20/2021 23:21:23:309 : 12036 : MESSAGE : End of IDE list.
11/20/2021 23:21:23:322 : 9912 : MESSAGE : Graph State Dump.
intel.oneapi.win.basekit.product,v=2021.4.0-3421, Enabled, Selected, Not Installed
intel.oneapi.win.basekit.getting_started,v=2021.4.0-3421, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2021.4.0-326, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2021.4.0-326, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.devel,v=2021.4.0-622, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.runtime,v=2021.4.0-622, Enabled, Selected, Not Installed
intel.oneapi.win.condaindex,v=2021.4.0-200, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2017,v=2021.4.0-364, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2017,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities,v=2021.4.0-832, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.common,v=2021.4.0-832, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2017,v=2021.4.0-832, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2019,v=2021.4.0-832, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler,v=2021.4.0-3556, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-dpcpp-common,v=2021.4.0-3556, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common,v=2021.4.0-3556, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2021.4.0-3556, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2021.4.0-3556, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger,v=10.2.4-67, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2017,v=10.2.4-67, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2017,v=10.2.4-67, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=10.2.4-67, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=10.2.4-67, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2021.4.0-3556, Enabled, Selected, Not Installed
intel.oneapi.win.dpl,v=2021.5.0-439, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2017,v=2021.4.0-364, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2017,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2017,v=2021.4.0-364, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2017,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2017,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2017,v=2021.4.0-364, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2021.4.0-364, Disabled, Not Selected, Not Installed
intel.oneapi.win.ipp.devel,v=2021.4.0-451, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.runtime,v=2021.4.0-451, Enabled, Selected, Not Installed
intel.oneapi.win.ippcp,v=2021.4.0-396, Enabled, Selected, Not Installed
intel.oneapi.win.dal.devel,v=2021.4.0-729, Enabled, Selected, Not Installed
intel.oneapi.win.dal.runtime,v=2021.4.0-729, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2021.4.0-640, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2021.4.0-640, Enabled, Selected, Not Installed
intel.oneapi.win.dnnl,v=2021.4.0-418, Enabled, Selected, Not Installed
intel.oneapi.win.python3,v=2021.4.0-3348, Enabled, Selected, Not Installed
intel.oneapi.win.dal.daal4py,v=2021.4.0-729, Enabled, Selected, Not Installed
intel.oneapi.win.dal.skleranex,v=2021.4.0-729, Enabled, Selected, Not Installed
intel.oneapi.win.mpi.runtime,v=2021.4.0-419, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.common,v=2021.4.0-398, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2017,v=2021.4.0-398, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2019,v=2021.4.0-398, Disabled, Not Selected, Not Installed
intel.oneapi.win.advisor,v=2021.4.0-383, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vsix,v=2021.4.0-383, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vs2017,v=2021.4.0-383, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vs2019,v=2021.4.0-383, Disabled, Not Selected, Not Installed
intel.oneapi.win.vpl,v=2021.6.0-458, Enabled, Selected, Not Installed
intel.oneapi.win.vtune,v=2021.7.1-471, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vsix,v=2021.7.1-471, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vs2017,v=2021.7.1-471, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vs2019,v=2021.7.1-471, Disabled, Not Selected, Not Installed
11/20/2021 23:21:23:328 : 9912 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Install intel.oneapi.win.basekit.getting_started,v=2021.4.0-3421
Install intel.oneapi.win.oneapi-common.vars,v=2021.4.0-326
Install intel.oneapi.win.oneapi-common.licensing,v=2021.4.0-326
Install intel.oneapi.win.condaindex,v=2021.4.0-200
Install intel.oneapi.win.tbb.runtime,v=2021.4.0-622
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2017,v=2021.4.0-364
Install intel.oneapi.win.tbb.devel,v=2021.4.0-622
Install intel.oneapi.win.dev-utilities.common,v=2021.4.0-832
Install intel.oneapi.win.dev-utilities.vs2017,v=2021.4.0-832
Install intel.oneapi.win.dev-utilities,v=2021.4.0-832
Install intel.oneapi.win.openmp,v=2021.4.0-3556
Install intel.oneapi.win.compilers-common-runtime,v=2021.4.0-3556
Install intel.oneapi.win.dpcpp_debugger.fee.vs2017,v=10.2.4-67
Install intel.oneapi.win.dpcpp_debugger.vsmi.vs2017,v=10.2.4-67
Install intel.oneapi.win.dpcpp_debugger,v=10.2.4-67
Install intel.oneapi.win.compilers-common,v=2021.4.0-3556
Install intel.oneapi.win.cpp-base-pro-common-runtime,v=2021.4.0-3556
Install intel.oneapi.win.cpp-dpcpp-common,v=2021.4.0-3556
Install intel.oneapi.win.dpl,v=2021.5.0-439
Install intel.oneapi.win.dpcpp-compiler.ide.vs2017,v=2021.4.0-364
Install intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2017,v=2021.4.0-364
Install intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2017,v=2021.4.0-364
Install intel.oneapi.win.dpcpp-compiler,v=2021.4.0-3556
Install intel.oneapi.win.ipp.runtime,v=2021.4.0-451
Install intel.oneapi.win.ipp.devel,v=2021.4.0-451
Install intel.oneapi.win.ippcp,v=2021.4.0-396
Install intel.oneapi.win.dal.runtime,v=2021.4.0-729
Install intel.oneapi.win.dal.devel,v=2021.4.0-729
Install intel.oneapi.win.mkl.runtime,v=2021.4.0-640
Install intel.oneapi.win.mkl.devel,v=2021.4.0-640
Install intel.oneapi.win.dnnl,v=2021.4.0-418
Install intel.oneapi.win.dal.daal4py,v=2021.4.0-729
Install intel.oneapi.win.dal.skleranex,v=2021.4.0-729
Install intel.oneapi.win.mpi.runtime,v=2021.4.0-419
Install intel.oneapi.win.python3,v=2021.4.0-3348
Install intel.oneapi.win.dpcpp_ct.vs2017,v=2021.4.0-398
Install intel.oneapi.win.dpcpp_ct.common,v=2021.4.0-398
Install intel.oneapi.win.advisor.vsix,v=2021.4.0-383
Install intel.oneapi.win.advisor.vs2017,v=2021.4.0-383
Install intel.oneapi.win.advisor,v=2021.4.0-383
Install intel.oneapi.win.vpl,v=2021.6.0-458
Install intel.oneapi.win.vtune.vsix,v=2021.7.1-471
Install intel.oneapi.win.vtune.vs2017,v=2021.7.1-471
Install intel.oneapi.win.vtune,v=2021.7.1-471
Install intel.oneapi.win.basekit.product,v=2021.4.0-3421
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
11/20/2021 23:21:23:597 : 9912 : MESSAGE : Start install/modify sequence execution.
11/20/2021 23:21:23:640 : 9912 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1637446883322864'.
11/20/2021 23:21:23:640 : 9912 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1637446883322864' execution is finished with status Success.
11/20/2021 23:21:23:640 : 9912 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1637446883322864'.
11/20/2021 23:21:23:640 : 9912 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1637446883322864' execution is finished with status Success.
11/20/2021 23:21:23:640 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.basekit.getting_started,v=2021.4.0-3421'.
11/20/2021 23:21:23:714 : 9912 : MESSAGE : Operation 'intel.oneapi.win.basekit.getting_started,v=2021.4.0-3421' execution is finished with status Success.
11/20/2021 23:21:23:714 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.vars,v=2021.4.0-326'.
11/20/2021 23:21:26:639 : 9912 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2021.4.0-326' execution is finished with status Success.
11/20/2021 23:21:26:639 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.licensing,v=2021.4.0-326'.
11/20/2021 23:21:26:884 : 9912 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2021.4.0-326' execution is finished with status Success.
11/20/2021 23:21:26:884 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.condaindex,v=2021.4.0-200'.
11/20/2021 23:21:27:093 : 9912 : MESSAGE : Operation 'intel.oneapi.win.condaindex,v=2021.4.0-200' execution is finished with status Success.
11/20/2021 23:21:27:093 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tbb.runtime,v=2021.4.0-622'.
11/20/2021 23:21:27:975 : 9912 : MESSAGE : Operation 'intel.oneapi.win.tbb.runtime,v=2021.4.0-622' execution is finished with status Success.
11/20/2021 23:21:27:975 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2017,v=2021.4.0-364'.
11/20/2021 23:21:28:253 : 9912 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2017,v=2021.4.0-364' execution is finished with status Success.
11/20/2021 23:21:28:253 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tbb.devel,v=2021.4.0-622'.
11/20/2021 23:21:30:926 : 9912 : MESSAGE : Operation 'intel.oneapi.win.tbb.devel,v=2021.4.0-622' execution is finished with status Success.
11/20/2021 23:21:30:926 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities.common,v=2021.4.0-832'.
11/20/2021 23:21:31:240 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.common,v=2021.4.0-832' execution is finished with status Success.
11/20/2021 23:21:31:240 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities.vs2017,v=2021.4.0-832'.
11/20/2021 23:21:31:402 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.vs2017,v=2021.4.0-832' execution is finished with status Success.
11/20/2021 23:21:31:402 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities,v=2021.4.0-832'.
11/20/2021 23:21:31:468 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities,v=2021.4.0-832' execution is finished with status Success.
11/20/2021 23:21:31:468 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.openmp,v=2021.4.0-3556'.
11/20/2021 23:21:43:626 : 9912 : MESSAGE : Operation 'intel.oneapi.win.openmp,v=2021.4.0-3556' execution is finished with status Success.
11/20/2021 23:21:43:626 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common-runtime,v=2021.4.0-3556'.
11/20/2021 23:21:46:493 : 9912 : MESSAGE : Operation 'intel.oneapi.win.compilers-common-runtime,v=2021.4.0-3556' execution is finished with status Success.
11/20/2021 23:21:46:493 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2017,v=10.2.4-67'.
11/20/2021 23:21:46:875 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2017,v=10.2.4-67' execution is finished with status Success.
11/20/2021 23:21:46:875 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger.vsmi.vs2017,v=10.2.4-67'.
11/20/2021 23:21:47:252 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.vsmi.vs2017,v=10.2.4-67' execution is finished with status Success.
11/20/2021 23:21:47:252 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger,v=10.2.4-67'.
11/20/2021 23:22:03:197 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger,v=10.2.4-67' execution is finished with status Success.
11/20/2021 23:22:03:197 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common,v=2021.4.0-3556'.
11/20/2021 23:22:07:314 : 9912 : MESSAGE : Operation 'intel.oneapi.win.compilers-common,v=2021.4.0-3556' execution is finished with status Success.
11/20/2021 23:22:07:314 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-base-pro-common-runtime,v=2021.4.0-3556'.
11/20/2021 23:22:10:706 : 9912 : MESSAGE : Operation 'intel.oneapi.win.cpp-base-pro-common-runtime,v=2021.4.0-3556' execution is finished with status Success.
11/20/2021 23:22:10:706 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-dpcpp-common,v=2021.4.0-3556'.
11/20/2021 23:22:23:298 : 9912 : MESSAGE : Operation 'intel.oneapi.win.cpp-dpcpp-common,v=2021.4.0-3556' execution is finished with status Success.
11/20/2021 23:22:23:298 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpl,v=2021.5.0-439'.
11/20/2021 23:22:23:684 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpl,v=2021.5.0-439' execution is finished with status Success.
11/20/2021 23:22:23:684 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp-compiler.ide.vs2017,v=2021.4.0-364'.
11/20/2021 23:22:24:035 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp-compiler.ide.vs2017,v=2021.4.0-364' execution is finished with status Success.
11/20/2021 23:22:24:035 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2017,v=2021.4.0-364'.
11/20/2021 23:22:24:313 : 9912 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2017,v=2021.4.0-364' execution is finished with status Success.
11/20/2021 23:22:24:313 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2017,v=2021.4.0-364'.
11/20/2021 23:22:24:610 : 9912 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2017,v=2021.4.0-364' execution is finished with status Success.
11/20/2021 23:22:24:610 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp-compiler,v=2021.4.0-3556'.
11/20/2021 23:22:26:005 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp-compiler,v=2021.4.0-3556' execution is finished with status Success.
11/20/2021 23:22:26:005 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.ipp.runtime,v=2021.4.0-451'.
11/20/2021 23:22:29:513 : 9912 : MESSAGE : Operation 'intel.oneapi.win.ipp.runtime,v=2021.4.0-451' execution is finished with status Success.
11/20/2021 23:22:29:513 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.ipp.devel,v=2021.4.0-451'.
11/20/2021 23:22:34:504 : 9912 : MESSAGE : Operation 'intel.oneapi.win.ipp.devel,v=2021.4.0-451' execution is finished with status Success.
11/20/2021 23:22:34:504 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.ippcp,v=2021.4.0-396'.
11/20/2021 23:22:36:739 : 9912 : MESSAGE : Operation 'intel.oneapi.win.ippcp,v=2021.4.0-396' execution is finished with status Success.
11/20/2021 23:22:36:739 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.runtime,v=2021.4.0-729'.
11/20/2021 23:22:39:786 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dal.runtime,v=2021.4.0-729' execution is finished with status Success.
11/20/2021 23:22:39:786 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.devel,v=2021.4.0-729'.
11/20/2021 23:22:52:972 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dal.devel,v=2021.4.0-729' execution is finished with status Success.
11/20/2021 23:22:52:972 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.mkl.runtime,v=2021.4.0-640'.
11/20/2021 23:23:06:217 : 9912 : MESSAGE : Operation 'intel.oneapi.win.mkl.runtime,v=2021.4.0-640' execution is finished with status Success.
11/20/2021 23:23:06:217 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.mkl.devel,v=2021.4.0-640'.
11/20/2021 23:23:22:213 : 9912 : MESSAGE : Operation 'intel.oneapi.win.mkl.devel,v=2021.4.0-640' execution is finished with status Success.
11/20/2021 23:23:22:213 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dnnl,v=2021.4.0-418'.
11/20/2021 23:23:26:618 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dnnl,v=2021.4.0-418' execution is finished with status Success.
11/20/2021 23:23:26:618 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.daal4py,v=2021.4.0-729'.
11/20/2021 23:23:35:868 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dal.daal4py,v=2021.4.0-729' execution is finished with status Success.
11/20/2021 23:23:35:868 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dal.skleranex,v=2021.4.0-729'.
11/20/2021 23:23:38:943 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dal.skleranex,v=2021.4.0-729' execution is finished with status Success.
11/20/2021 23:23:38:943 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.mpi.runtime,v=2021.4.0-419'.
11/20/2021 23:23:44:877 : 9912 : MESSAGE : Operation 'intel.oneapi.win.mpi.runtime,v=2021.4.0-419' execution is finished with status Success.
11/20/2021 23:23:44:877 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.python3,v=2021.4.0-3348'.
11/20/2021 23:25:47:940 : 9912 : MESSAGE : Operation 'intel.oneapi.win.python3,v=2021.4.0-3348' execution is finished with status Success.
11/20/2021 23:25:47:940 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2017,v=2021.4.0-398'.
11/20/2021 23:25:48:332 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.vs2017,v=2021.4.0-398' execution is finished with status Success.
11/20/2021 23:25:48:332 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.common,v=2021.4.0-398'.
11/20/2021 23:25:48:991 : 9912 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.common,v=2021.4.0-398' execution is finished with status Success.
11/20/2021 23:25:48:991 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.advisor.vsix,v=2021.4.0-383'.
11/20/2021 23:25:49:306 : 9912 : MESSAGE : Operation 'intel.oneapi.win.advisor.vsix,v=2021.4.0-383' execution is finished with status Success.
11/20/2021 23:25:49:306 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.advisor.vs2017,v=2021.4.0-383'.
11/20/2021 23:25:49:470 : 9912 : MESSAGE : Operation 'intel.oneapi.win.advisor.vs2017,v=2021.4.0-383' execution is finished with status Success.
11/20/2021 23:25:49:470 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.advisor,v=2021.4.0-383'.
11/20/2021 23:25:59:998 : 9912 : MESSAGE : Operation 'intel.oneapi.win.advisor,v=2021.4.0-383' execution is finished with status Success.
11/20/2021 23:25:59:998 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.vpl,v=2021.6.0-458'.
11/20/2021 23:26:01:009 : 9912 : MESSAGE : Operation 'intel.oneapi.win.vpl,v=2021.6.0-458' execution is finished with status Success.
11/20/2021 23:26:01:009 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.vtune.vsix,v=2021.7.1-471'.
11/20/2021 23:26:01:902 : 9912 : MESSAGE : Operation 'intel.oneapi.win.vtune.vsix,v=2021.7.1-471' execution is finished with status Success.
11/20/2021 23:26:01:902 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.vtune.vs2017,v=2021.7.1-471'.
11/20/2021 23:26:02:061 : 9912 : MESSAGE : Operation 'intel.oneapi.win.vtune.vs2017,v=2021.7.1-471' execution is finished with status Success.
11/20/2021 23:26:02:061 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.vtune,v=2021.7.1-471'.
11/20/2021 23:26:34:794 : 9912 : MESSAGE : Operation 'intel.oneapi.win.vtune,v=2021.7.1-471' execution is finished with status Success.
11/20/2021 23:26:34:794 : 9912 : MESSAGE : Starting execution of operation 'intel.oneapi.win.basekit.product,v=2021.4.0-3421'.
11/20/2021 23:26:34:957 : 9912 : MESSAGE : Operation 'intel.oneapi.win.basekit.product,v=2021.4.0-3421' execution is finished with status Success.
11/20/2021 23:26:34:957 : 9912 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1637446883322864'.
11/20/2021 23:26:35:014 : 9912 : WARNING : Product configuration is not finished successfully. Integration in IDE(s) might be in incomplete state or custom post-install/remove scripts might fail.
Details: Error: Sequence execution failed.
11/20/2021 23:26:35:014 : 9912 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1637446883322864' execution is finished with status SuccessWithFail.
11/20/2021 23:26:35:014 : 9912 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1637446883322864'.
11/20/2021 23:26:35:059 : 9912 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1637446883322864' execution is finished with status Success.
11/20/2021 23:26:35:059 : 9912 : ERROR : Install sequence execution status: SuccessWithFail
Hi Andrew, please note that Windows 11 is not among the list of supported platforms for the toolkit. Please click here: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html, to know more.
Also, please check whether you meet the necessary GPU requirements to run the toolkit. To know more, check the Requirements for Accelerators section of the above link.
Windows 11 is not the problem.
For a possible workaround to the Intel oneAPI installer bug, please see here:
Hi Andrew, we see that multiple threads have been created under your profile regarding this same issue. Thus, we are going ahead and closing this thread and we will continue our support on the parent thread, here> https://community.intel.com/t5/Intel-oneAPI-Registration/oneAPI-Base-Toolkit-failes-to-integrate-with-VS2017/m-p/1339681/highlight/true#M1899
