Environment:- Ubuntu 18.04 on CLX.
Error generating step:-
2. b. Run the Docker and work from a container:
If you have proxy set up:
sudo -E docker run --name renderkit --rm -it --privileged -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/ tmp/.X11-unix -e HTTP_PROXY=$HTTP_PROXY -e HTTPS_PROXY=$HTTPS_PROXY -e http_proxy=$http_proxy -e https_proxy=$https_proxy ubuntu bash
Error:-
docker: invalid reference format: repository name must be lowercase.
See 'docker run --help'.
Could you please try the below command.
sudo -E docker run --name renderkit --rm -it --privileged -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -e HTTP_PROXY=$HTTP_PROXY -e HTTPS_PROXY=$HTTPS_PROXY -e http_proxy=$http_proxy -e https_proxy=$https_proxy ubuntu bash
There is small correction in the command given in the documentation.An extra space added after "/" tmp.
The documentation fix request has been submitted to document owners. Thanks.
-MichaelC
Hi Hemanth,
Could you please confirm whether the issue got resolved.
Hi Hemanth,
Hope your issue got resolved. We are closing this thread. Please feel free to open a new thread if you have any further queries.
For more complete information about compiler optimizations, see our Optimization Notice.
