20100406 open-source release
Changes (w.r.t. 20100310 open-source release):
- Added support for Microsoft* Visual Studio* 2010, including binaries.
- Added parallel_pipeline function and companion classes and functions
that provide a strongly typed lambda-friendly pipeline interface.
- Reworked enumerable_thread_specific to use a custom implementation of
hash map that is more efficient for ETS usage models.
- Added example for class task_group; see examples/task_group/sudoku.
- Removed two examples, as they were long outdated and superceded:
pipeline/text_filter (use pipeline/square);
parallel_while/parallel_preorder (use parallel_do/parallel_preorder).
- Other fixes and changes in code, tests, and examples.
Bugs fixed:
- Eliminated build errors with MinGW32.
- Fixed post-build step and other issues in VS projects for examples.
- Fixed discrepancy between scalable_realloc and scalable_msize that
caused crashes with malloc replacement on Windows.
--Vladimir
OutputFunc myOutputFuncObject_;
Yes, the functors are copied by value in order to support lambdas. Using move constructors would have been better, but that requires C++0x support.
We had long debates over the flow_control feature. We needed some way for the first filter to indicate end-of-stream. Returning NULL was no longer an option because the functors can return a value of any type, not just pointer types. Proposed solutions were:
- Have the filter return a std::pair
, where the bool indicated whether end-of-file had been reached. - Have the filter return some kind of wrapper that would hold either the value or a special bool value.
- Have the filter return a special value marking end of file, and let the user specific the special value.
- The flow_control feature.
The flow_control variant seemed to be the least evil.
I guess this functionality is mostly for lambdas.... but would be nice if one could use function objects and the like.
The reason for storing a copy is that the filter can be constructed using a temporary object (not necessary a lambda but a function objects as well) outside of the expression that starts parallel_pipeline:
If body is stored by reference, this won't work because the temporaries are destroyed before the call to parallel_pipeline. Actually, I am not sure how rvalue references would help in this usage scenario. We do the same in class tbb_thread; the auxiliary thread_closure class holds a copy of function object in order to pass it to another OS thread.
Anyway, I think it should not be a huge issue. Generally, function objects are supposed to be small and copy-constructible easily; all heavy and/or changing state should better be kept in separate instances referenced from the function object.
Actually, looking at the code I see that we do have this problem! Because the copies are createdexactly in the call to parallel_pipeline, not earlier. Surprise surprise :)
Or go into the documentation instead (which is not yet available but will be, soon).
Passing by value could cause creation ofanother, excessivecopy. I am not sure all compilers would be able to eliminate it.
And if a functor is passed by pointer, then a user has no choice.
Plus pass by value is safer in a single-threaded context, and a way safer and faster in a multi-threaded context.
Wrt misunderstandings, pass by value functors/allocators are used in C++ for years. So IMVHO in the context of C++ it's quite expected behavior.
--Vladimir
