2456 Discussions
32 bit installation of tbb in a 64 bit linux machine
Ankur_B_
I am trying to install tbb from source as 32 bit in a 64 bit linux machine. Can anyone guide how to make tbb as 32 bit forcefully in a 64 bit machine.
I already tried this.
 CONFIG: cfg=debug arch=ia32 compiler=gcc target=linux runtime=cc4.1.2_libc2.5_kernel2.6.18
but still the -m64 flag is appearing in the compilation, I need to change it to -m32.
Maksim_D_Intel
Hello
Which version of TBB do you use?
Could you please try to execute make tbb tbbmalloc arch=ia32  in src directory.
Maksim_D_Intel
Hello
