ARM build for TBB
jmkrishna
I would like to port TBB on ARM machine.
Can anyone please provide patch for it and
other information for ARM build.
Thanks in advance.
JMKrishna.
RafSchietekat
Black Belt
Do you really mean port, or apply (since you're asking for a patch)? What environment (compiler, operating system, kind of system)?
If it's GCC-based, TBB already has a generic implementation to at least get you started.
Vladimir_P_1234567890
helloJMKrishna,
I'm not aware about current limitations for linux on arm. The current version might work there.
Please post your feedback after you try.
thanks.
--Vladimir
jmkrishna
Thank u for reply.
I want to use it on Android.
Can i use it directly or any patch is required for that one??
JMKrishna
RafSchietekat
Black Belt
If anybody has done that already, I don't think it has been mentioned here before. It's a bit more specific than just the processor, I suppose, but why not give it a try and tell us what you see?
