Community
cancel
Showing results for
Search instead for
Did you mean:
Franco_M_
Adding new work to parallel do
Dear all,
in a previous post (this link) I've asked if TBB could help me in writing my software, and it turns out it is perfect for my job. I've got, however, a problem in adding new work to a parallel_do routine.
Let me recap the objective, reconstruct a particle path with an iterative solution (this image may help you):
  • each path point has an initial position
  • when the first solution to the coordinates are found, the next point starts
  • after adding the new point, the coordinates are optimized
The following code is a simulation of what I'd like to have. Each path node has an an integer ID, and I'd like to have 10 points, just to understand how I can parallelize the whole thing. Moreover, as a bonus, I'd like to retain all the path nodes in a vector (or any other container), but I don't know what's best for this objective.
I must be doing some stupid errors, since I always get ID zero.
This is my code:
#include <tbb/task_scheduler_init.h>
#include <tbb/parallel_for.h>
#include <tbb/parallel_do.h>
#include <tbb/concurrent_vector.h>
class pathnode
    int id_;
    std::mutex &m_;
    tbb::concurrent_vector<pathnode> &v_;
public:
    pathnode(int id, tbb::concurrent_vector<pathnode> v, std::mutex &mtx) : id_(id), v_(v), m_(mtx)
        // NOP
    void operator()(pathnode item, tbb::parallel_do_feeder<pathnode> &feeder) const
            std::lock_guard<std::mutex> l(m_);
            std::cout << "START thread id " << this_thread::get_id() << " ID " << id_ << std::endl;
        // Simulate initializing the path coordinates
            std::mt19937_64 eng{std::random_device{}()};
            std::uniform_int_distribution<> dist{100, 1000};
            auto p = std::chrono::milliseconds{dist(eng)};
            std::this_thread::sleep_for(p);
        // Add more work to perform
        if (id_ < 10)
            feeder.add(pathnode(id_ + 1, v_, m_));
        // Simulate optimizing coordinates
            std::uniform_int_distribution<> dist{1000, 2000};
            std::cout << "ENDED thread id " << this_thread::get_id() << " ID " << id_ << std::endl;
int main(int argc, char** argv)
    std::mutex m;
    tbb::concurrent_vector<pathnode> trajectory;
    pathnode initial(0, trajectory, m);
    trajectory.push_back(initial);
    tbb::parallel_do(trajectory.begin(), trajectory.end(), trajectory.back());
    return 0;
The output isn't particularly good:
START thread id 0x104c03000 ID 0
START thread id 0x700000804000 ID 0
START thread id 0x700000c07000 ID 0
ENDED thread id 0x104c03000 ID 0
START thread id 0x700000401000 ID 0
ENDED thread id 0x700000804000 ID 0
ENDED thread id 0x700000c07000 ID 0
ENDED thread id 0x700000401000 ID 0
Program ended with exit code: 9
I stopped it.
Can you help me?
Thanks!
     Franco
Alexei_K_Intel
Hi Franco,
In my opinion, the main issue that the code is a bit complicated: the Item and Body functionality are merged into one class. Undoubtedly, it is not error or something unusual but if consider the line:
we can see that we access the "id_" from "this" (i.e. Body) not from "item" (that was previously added to the feeder).
On the line:
The third argument is Body and it is used for all invocations of
So "this->id_" is always 0 (because "initial.id_" == 0).
I'd suggest adding a special class for Body:
struct Body {
    void operator()(pathnode item, tbb::parallel_do_feeder<pathnode> &feeder) const {
        item( feeder );
And use it in parallel_do (do not forget to fix functor of pathnode) :
tbb::parallel_do(trajectory.begin(), trajectory.end(), Body());
As for concurrent_vector, it will work until the container that does not invalidate iterator is used. I.e. if push_back (or similar interface) does not invalidate iterators then such container can be used like in the example.
One more remark that parallel_do allows specifying the whole container instead of iterators, i.e.
tbb::parallel_do(trajectory, Body);
Franco_M_
Thanks Alaxei, it worked!
I don't understand if what I did is dangerous:
        if (id_ < 10)
            auto p = v_.push_back(pathnode(id_ + 1, v_, m_));
            feeder.add(*p);
I need to keep all the points in the vector, but I don't know if those lines may bring me some kind of race condition. Do you think that code is ok?
Thanks!
