Archive versions of TBB
Gabor_N_
I am looking for older versions of TBB (2.0 commaligned and 3.x commaligned). Can anyone please point me to the right link? I could not find it. Thank you in advance.
Vladimir_P_1234567890
hello,
if you are a beginner, I suggest to look at our automatic malloc replacement: C/C++ Dynamic Memory Interface Replacement
Older releases can be found in Linux distributions, for example:
RPM-based distrbiutions (Fedora, CentOS, etc):
http://rpmfind.net/linux/rpm2html/search.php?query=tbb-devel
http://koji.fedoraproject.org/koji/buildinfo?buildID=36038
Ubuntu:
https://launchpad.net/ubuntu/+source/tbb
--Vladimir
RafSchietekat
Black Belt
I don't think there is such a resource. Why would you want this?
Gabor_N_
First of all I am a total beginner to TBB but I am using it for a while and I am amazed with the performance gain. I am using TBBMM memory manager for Delphi 32 bit. Since it is a 32 bit non open source project I would like to extend it for 64 bits (as an open source code project) and as a start I thought it will be easier to rewrite the 32 bit version using the older 2.0 TBB (and 3) just like TBBMM writer did.
I would be surprised if no one ever archived the older versions of TBB.
hello,
Ubuntu:
--Vladimir
Gabor_N_
Vladimir: Thank you for your help. It is indeed what I am searching for.
