Are condition variables officially supported?
christian_conveygmai
Hi guys,
Can anyone tell me what's going on with TBB support for condition variables?
I'm developing an app that is using TBB for multi-tasking, and I need condition variables.  I found an article here:  http://software.intel.com/en-us/blogs/2010/10/01/condition-variable-support-in-intel-threading-building-blocks suggesting that they're supported by TBB.
But the condition_variable header file is burried in the "compat" subdirectory, and it doesn't show up in the HTML docs for TBB 4.0 (update 1).  That makes me wonder if the condition_variable class is going away soon, or is in some other way unsupported.
Is the idea that TBB really wants me to be using C++11's condtion_variable class, and this is just a nicety for compilers which don't yet support that part of C++11?
RafSchietekat
Valued Contributor III
Yes. Note that the class is not used by anything else in TBB (4.1 update 2), and that blocking on a mutex should be avoided inside a TBB task (blocking leads to undersubscription or worse), where a dummy_task dependency may be an appropriate replacement for a condition_variable.
Okay, thanks.  Apparently I'm not as up on C++11 features as I should have been, or else I would have noticed the the concurrency constructs in Boost and TBB were basically drop-in replacements for those in C++11.
RafSchietekat
My impression is that boost often leads new standard functionality.
