Dear all,
I am outputting some computed results per short time period.
In order to achieve the benefits of concurrency, I am considering to introduce asynchronous IO.
Just output of data in memory to files is so simple that I wondering if executing task for outputting is met for my purpose.
On the other hand, I know there is some library for asynchronous IO (boost::asio etc).
Is TBB properly working with such a thread libraries? Or, should I close my methods in TBB?
I always thank for helpful comments of experts.
Kind regards
Dear Mitsuru,
The general recommendation is to avoid IO operations on TBB worker threads (because it might reduce CPU utilization). So you can create a dedicated thread (or threads) and request them to perform IO operations when necessary. To organize communications between threads, you may want to consider tbb::concurrent_bounded_queue or tbb::flow::async_node.
Alex
