Barrier synchronization in tbb threads
akhal
Hej
I am new to intel TBB. I am trying to parallelize a looping structure with parallel_for. Structure of code is like:
for i=0:size
for j=i+1:size
------do something------
for j=i+1:size
for k=i+1:size
---do something---
for i=0:size
parallel_for(i+1:size) with looping
parallel_for(i+1:size) with nested looping
But this has drastically slowed down my speedup even much below than serial execution:( I rather need a parallelized structure of the form:
parallel_for(i,size)
for j=i+1:size
/*------SYNCHRONIZATION-BARRIER------------*/
for j=i+1:size
for k=i+1:size
---do something---
i-e synchronization barrier of MPI kind that the second looping structure only begins when first looping has finished, so I guess i will get some speedup.... I have no idea if intel tbb has this kind of barrier, I looked through synchronization structures but they only talk about mutexes for shared variable accesses... Need urgent help with this, and thanks so much in advance....
RafSchietekat
Valued Contributor III
