Benchmark written in TBB
irisshinra308
Hi~
I am new to Intel TBB and trying to make some modification to it.
However, I am wondering if there are some benchmarks or applications which are written in TBB.
Any help would be grateful
Thanks for reading
Dennis
Dmitry_Vyukov
Valued Contributor I
Quoting - irisshinra308
Hi~
Thanks for reading
Dennis
In open-source source distribution you can find some benchmarks and tests in folders:
src/test/
src/perf/
Although, they are synthetic tests, not full-fledged applications.
IKlm
Quoting - Dmitriy Vyukov
src/test/
src/perf/
Can you explain, please, how I can compile and run src/perf content?
And do you know, if is some there standard benchmark, which test ability of processor to run different number of threads? I need some kind of time = time(NumberOfThreads) distribution.
Thanks in advice,
Igor.
Anton_M_Intel
Quoting - IKlm
Please try gmake time_{testname} [args={test arguments}] from src/ directory. E.g. "gmake time_hash_map_fill args=1:16"
Each test has its own command line specifics and usage model but number of threads usually passed in "min:max" form.
Prasun_Gera__Intel_
Also, you can try the PARSEC benchmark suite for your analysis. You can run the serial/pthreads/openmp versions of the packages as well to compare your results.
softarts
could you check this:
linaspl27:/tbb/src # gmake time_hash_map_fill args=1:8
gmake -C "../build/linux_intel64_gcc_cc4.1.2_libc2.4_kernel2.6.16.60_release" -r -f ../../build/Makefile.test cfg=release run_cmd="" tbb_root=../.. time_hash_map_fill
gmake[1]: Entering directory `/home/misc.prj/tbb22_20091101oss/build/linux_intel64_gcc_cc4.1.2_libc2.4_kernel2.6.16.60_release'
g++ -c -MMD -DDO_ITT_NOTIFY -O2 -DUSE_PTHREAD -m64 -Wall -I../../src -I../../src/rml/include -I../../include ../../src/perf/time_hash_map_fill.cpp
In file included from ../../src/perf/time_hash_map_fill.cpp:123:
../../src/perf/time_sandbox.h:46:23: error: tbb/concurrent_hash_map-5468.h: No such file or directory
../../src/perf/time_sandbox.h:48: error: concurrent_hash_map is not a member of sandbox2::tbb
../../src/perf/time_sandbox.h:48: error: template argument 1 is invalid
../../src/perf/time_sandbox.h:48: error: expected unqualified-id before , token
../../src/perf/time_sandbox.h:48: error: expected unqualified-id before numeric constant
../../src/perf/time_sandbox.h: In member function void test_sandbox::factory(arg_t, int):
../../src/perf/time_sandbox.h:140: error: expected type-specifier
../../src/perf/time_sandbox.h:140: error: expected `)'
../../src/perf/time_framework.h: In constructor TestRunner::TestRunner(const char*, Test*) [with Test = int]:
../../src/perf/time_framework.h:292: instantiated from TestRunner* TestProcessor::run(const char*, Test*) [with Test = int]
../../src/perf/time_sandbox.h:140: instantiated from here
../../src/perf/time_framework.h:179: error: invalid static_cast from type int* to type TesterBase*
gmake[1]: *** [time_hash_map_fill.o] Error 1
gmake[1]: Leaving directory `/home/misc.prj/tbb22_20091101oss/build/linux_intel64_gcc_cc4.1.2_libc2.4_kernel2.6.16.60_release'
gmake: *** [time_hash_map_fill] Error 2
Anton_M_Intel
Quoting - softarts
The benchmark is supposed to compare two or more implementstions on the same dataset and operations. But TBB comes with only one implementation of the hash table (still). Check the configuration in the first lines of the time_hash_map_fill.cpp, BOX2 defines the second implementation which is not available by default. E.g. you could use concurrent_hash_map from TBB 2.1 to check the performance difference with new algorithm in 2.2.
