2464 Discussions
Binary compiled with Clang++ 5.5.0 on GNU/Linux crashes [TBB 2018U1]
Germán_M_
Hello there:
I am trying to compile my C++ 14 code with Clang++ 5.0.0 on GNU/Linux using TBB 2018 update 1. Everything works fine with g++ 7.2.0 and Intel C++ Compiler 18, but when I try to switch to Clang++, it compiles but it crashes when I try to run it. Even, a simple hello world appliccation crashes when link it with TBB.
I am using the following module for detecting TBB from my system with cmake 3.9.3. The error is the following:
When I run it from terminal:
terminating with unexpected foreign exception
Aborted (core dumped)
When I run it from Clion 2017.2.3:
Process finished with exit code 134 (interrupted by signal 6: SIGABRT)
Also, I have tried to compile TBB from source code using Clang++ and libc++ but without success. I got a linker error. But when I try to compile only with Clang++ (without libc++), TBB compile with success. Also, using the compiled TBB also crashed the binary.
I have tried the following linker flags (obtained from here):
-DCMAKE_EXE_LINKER_FLAGS="-lc++abi"
-DCMAKE_EXE_LINKER_FLAGS="-lc++ -lc++abi -lm -lc -lgcc_s -lgcc"
I am using Linux kernel 4.13.3. Clang++ 5.5.0, Intel C++ compiler 18.0.0 20170811 and g++ 7.2.0.
Am I missing something or doing something in the wrong way?
Thanks in advance.
