Broken download links
kerursiv
  The download page is not currently working, with broken links to all of the downloads.  For example, the Windows version links to the following file which doesn't exist:
http://www.threadingbuildingblocks.org/sites/default/files/software_releases/windows/tbb41_20130613oss_win.zip
   Is anyone else having this issue, and if so can this be fixed?
Thanks!
robert-reed
Valued Contributor II
Yes, I had a similar experience.  Appears that ALL the file download links are broken.  Though this may be a temporary problem with our fullfillment provider, I'll raise the alarm to try to escalate a fix.  Thanks for reporting this.
robert-reed
This problem should now be fixed.  Apparently there were some imperfect migration scripts employed during a recent upgrade and the files never got copied over.  That should be fixed now.  Thanks for alerting us to the issue.
kerursiv
   Great, it works.  Thanks for the quick fix!
RafSchietekat
Valued Contributor III
Maybe the problems I'm now experiencing on the contributions page are related? http://www.threadingbuildingblocks.org/submit-contribution, Next, "Safari can't open the page/Too many redirects occurred [...]".
Vladimir_P_1234567890
indeed. i've sent the information to the support team.
Most of the issues with site  were adressed. Let us know if you are still facing with any.
thanks.
--Vladimir
