Bug in TBB With ref_count() ?
AJ13
I'm really not sure if this is a bug or not, it seems to be. The following code causes an assertion (compiled without optimizations):
Assertion 1L<state() & (1L<<:ALLOCATED>Aborted
Here's the code:
#include
#include
#include
class HelloTask : public tbb::task
public:
HelloTask(int depth) : _depth(depth) { }
tbb::task* execute()
if(_depth == 0) return 0;
HelloTask& a = *new ( allocate_child() ) HelloTask(_depth - 1);
HelloTask& b = *new ( allocate_child() ) HelloTask(_depth - 1);
set_ref_count(ref_count() + 1);
spawn(a);
spawn(b);
int tmp;
for(int i = 0; i < 1000000; ++i)
tmp = tmp*i;
wait_for_all();
return 0;
private:
int _depth;
int main()
tbb::task_scheduler_init init;
HelloTask& a = *new ( tbb::task::allocate_root() ) HelloTask(10);
tbb::task::spawn_root_and_wait(a);
RafSchietekat
Valued Contributor III
Once you spawn a child, you must not use set_ref_count() again; use allocate_additional_child_of() instead.
AJ13
Quoting - Raf Schietekat
Aha, thanks.
