I believe I've found a bug in tbbmalloc relating to scalable_aligned_realloc & scalable_msize. In the code below all my asserts will fire.
#include <...> #define ARRAY_COUNT(x) (sizeof(x)/sizeof(x[0])) static const uintptr_t slabSize = 16 * 1024; static uintptr_t findAllocationOffset(const void* address, size_t objectSize) { uintptr_t base = (uintptr_t)address & ~(slabSize - 1); // calculate offset from the end of the block space uint16_t offset = base + slabSize - (uintptr_t)address; // find offset difference from a multiple of allocation size offset %= objectSize; // and move the address down to where the real object starts. return offset ? objectSize - offset : 0; } void main() { static const size_t AllocCount = 4; void* Ptrs[AllocCount] = { 0 }; size_t Sizes[AllocCount] = { 0 }; for (uint32 i = 0; i < ARRAY_COUNT(Ptrs); ++i) { Sizes = 3680; Ptrs = scalable_aligned_malloc(Sizes, 128); } for (uint32 i = 0; i < ARRAY_COUNT(Ptrs); ++i) { Sizes = 4016; Ptrs = scalable_aligned_realloc(Ptrs, Sizes, 128); } /** Check that pointer offsets & sizes make sense (the block size should be 4032) */ for (uint32 i = 0; i < ARRAY_COUNT(Ptrs); ++i) { size_t alloc_size = scalable_msize(Ptrs); uintptr_t alloc_offset = findAllocationOffset(Ptrs, alloc_size); assert(alloc_size + alloc_offset == 4032); } /** Check an allocation hasn't gone outside the slab */ for (uint32 i = 0; i < ARRAY_COUNT(Ptrs); ++i) { assert(((uintptr_t)Ptrs & ~(slabSize - 1)) == (((uintptr_t)Ptrs + (Sizes - 1)) & ~(slabSize - 1))); } /** Check an allocation doesn't overlap with another */ for (uint32 i = 0; i < ARRAY_COUNT(Ptrs); ++i) { for (uint32 j = 0; j < ARRAY_COUNT(Ptrs); ++j) { if (i != j) { assert((UPTRINT)Ptrs < (UPTRINT)Ptrs|| (UPTRINT)Ptrs >= (UPTRINT)Ptrs + Sizes ); } } } for (uint32 i = 0; i < ARRAY_COUNT(Ptrs); ++i) { scalable_free(Ptrs); } }
Basically, I believe the both scalable_aligned_realloc and scalable_msize fail to account for alignment offsets in a small allocation bin.
With scalable_msize() the function internalMsize appears to be wrong.
if (ptr) { ... if (isLargeObject(ptr)) { ... } else { Block* block = (Block *)alignDown(ptr, slabSize); #if MALLOC_CHECK_RECURSION size_t size = block->getSize()? block->getSize() : StartupBlock::msize(ptr); #else size_t size = block->getSize(); #endif ... return size; } }
But "return size;" shoud be something like "return size - findAllocationOffset(ptr, block->getSize());"... I think :)
With scalable_aligned_realloc() the function reallocAligned appears to fail here:
Block* block = (Block *)alignDown(ptr, slabSize); copySize = block->getSize(); if (size <= copySize && (0==alignment || isAligned(ptr, alignment))) { return ptr;
Again, I think that "copySize = block->getSize();" should be something along the lines of "copySize = block->getSize() - findAllocationOffset(ptr, block->getSize());" otherwise realloc will return allocations that overlap each other.
Hopefully that made sense :)
Thanks,James
Thanks for the reply.
If there is a bug fix put in for this, what kind of time frame am I looking at until it would be released? Would it be just released with the next 4.x version update?
Thanks, James
hello James,
This issue will be addressed in one of next releases. we will put a message to this thread when the fix is available.
--Vladimir
