Build TBB on PowerPC-64 running linux
lakshminarayanan_r
I am new to the forum. I am trying to build the latest stable version of TBB on a powerpc 64 bit machine running linux. I searched in the forum and web but could not find instructions on how to build TBB on this platform. Has anyone tried to build TBB on ppc-linux? Thanks for any suggestions/help.
Ln
Vladimir_P_1234567890
hi, first of allI suggest to use the latest comm-align version. it is a bit newer than the latest stable version and it is also quite stable.
Porting instructions are located in build/index.html file in source package.
at first glanceport looks to be as simple as adding following lines under "#elif __linux__ || __FreeBSD__" directive, line 64 in include/tbb/tbb_machine.h file.
#elif __POWERPC__
#include "machine/mac_ppc.h"
But who knows:)
--Vladimir
lakshminarayanan_r
#elif __POWERPC__
But who knows:)
--Vladimir
Hello Vladimir,
Thanks for the quick reply. I tried your suggestion. After adding the suggested two lines to tbb_machine.h, I tried to do a make at the top-level dir. The make complained that the architecture is not recognized. Then I added the following lines to build/linux.inc
ifeq ($(uname_m),ppc64)
export arch:=ppc
endif
With the above change to linux.inc, I ran make. The compilation terminates with the following (attached at the end) errors. To my inexperienced eye, it looks like the some definitions for some synchronization related macros/functions are missing.
Thanks for the suggestions and help.
cd "./build/linux_ppc_gcc_cc4.1.2_libc2.5_kernel2.6.18_release" && sh ../../build/generate_tbbvars.sh linux_ppc_gcc_cc4.1.2_libc2.5_kernel2.6.18_release
cd "./build/linux_ppc_gcc_cc4.1.2_libc2.5_kernel2.6.18_debug" && sh ../../build/generate_tbbvars.sh linux_ppc_gcc_cc4.1.2_libc2.5_kernel2.6.18_debug
gmake -C "./build/linux_ppc_gcc_cc4.1.2_libc2.5_kernel2.6.18_debug" -r -f ../../build/Makefile.tbb cfg=debug tbb_root=../..
gmake[1]: Entering directory `/gsa/yktgsa-h1/08/lrengan/MyTools/tbb22_009oss/build/linux_ppc_gcc_cc4.1.2_libc2.5_kernel2.6.18_debug'
../../build/Makefile.tbb:39: CONFIG: cfg=debug arch=ppc compiler=gcc os=linux runtime=cc4.1.2_libc2.5_kernel2.6.18
g++ -c -MMD -DTBB_USE_DEBUG -DDO_ITT_NOTIFY -g -O0 -DUSE_PTHREAD -fPIC -D__TBB_BUILD=1 -Wall -Wno-parentheses -I../../src -I../../src/rml/include -I../../include ../../src/tbb/concurrent_hash_map.cpp
In file included from ../../include/tbb/spin_rw_mutex.h:33,
from ../../include/tbb/concurrent_hash_map.h:40,
from ../../src/tbb/concurrent_hash_map.cpp:29:
../../include/tbb/tbb_machine.h:98:2: error: #error Minimal requirements for tbb_machine.h not satisfied
../../include/tbb/tbb_machine.h: In function 'T __TBB_load_with_acquire(const volatile T&)':
../../include/tbb/tbb_machine.h:106: error: there are no arguments to '__TBB_release_consistency_helper' that depend on a template parameter, so a declaration of '__TBB_release_consistency_helper' must be available
../../include/tbb/tbb_machine.h:106: error: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
../../include/tbb/tbb_machine.h: In function 'void __TBB_store_with_release(volatile T&, V)':
../../include/tbb/tbb_machine.h:115: error: there are no arguments to '__TBB_release_consistency_helper' that depend on a template parameter, so a declaration of '__TBB_release_consistency_helper' must be available
../../include/tbb/tbb_machine.h: In function 'void __TBB_Pause(int32_t)':
../../include/tbb/tbb_machine.h:122: error: '__TBB_Yield' was not declared in this scope
../../include/tbb/tbb_machine.h: In member function 'void tbb::internal::atomic_backoff::pause()':
../../include/tbb/tbb_machine.h:148: error: '__TBB_Yield' was not declared in this scope
---------- More error messages. I have posted above only a part of it. -----------------
Ln
keiisn
Hello Vladimir,
export arch:=ppc
endif
Ln
I got this mostly working with TBB 2.1. Raf Schietekat then fixed a previously existing low-level PowerPC implementation issue, whereupon we apparently had a properly functional Linux/PPC port. This should all be documented in an earlier thread. I don't know why these changes weren't incorporated in the the release tree--as I recall Raf was diligent about uploading files/patches.
(Where's the search-the-forum functionality???)
Kei
Ryan_B_1
Quoting - keiisn
Found it! (I seem to have two identities here.) I'm just getting back into this. Here's the thread.
http://software.intel.com/en-us/forums/showthread.php?t=59929
Ryan_B_1
Ln
Hey, if you're still interested I have the whole tree for version 2.1, just let me know.
Kei
lakshminarayanan_r
Quoting - Kei
Kei
Hi Kei,
Yes, I am interested.
I tried your previous suggestion: I read that post and tried to apply the patch. But, I could not get a working version.
So, if you have a version that might work, I would be very happy to try it out immediately.
Thanks for the help.
Ln
Ryan_B_1
Hi Kei,
Ln
The easiest way for me to do this is to use our local file transfer interface, for which I'd need you email address. You'd be emailed a notice of file availability and some sort of one-time access key. Let me know--kei.davis@lanl.gov.
Andriy_Kot
Kei,
I found this thread while looking for a way to run my tbb code on a power5/linux system. I would appreciate if you could send me the tree as well. I will email you. Thanks
Andriy
PS To all: any idea if/when ppc64/linux platform will be supported?
Jeffrey_H_Intel
Intel TBB was ported to PowerPC 32/64 for Linux and Blue Gene CNK over the past few years.  It's being used on Blue Gene/Q (64-bit PowerPC with Linux-compatible OS) today.
