Building TBB as a static library on Linux
Jogi_Narain
I understand that this is not the most optimum way of using TBB but can I build a static library on Linux? I have seen this (and done it) on Windows.
Is it just a matter of modifying the Makefiles?
sreenu30
Quoting - Jogi Narain
I am also looking for this. I tried modifying the Makefiles, but it didnt work for me. Has someone got it working?
Jogi_Narain
Quoting - sreenu30
I still haven't managed to get a static build done but I have now been able incorporate the dynamic library into an existing binary by linking against the dynamic library.
Not really a satisfactory solution but it allows me to continue.
Vivek_Rajagopalan
IIRC, there are issues with static linking due to ownership issues of certain singletons. I don't know if this is still the case with tbb 2.2
Unless you really know what you are doing, I'd stay with dynamic linking. If you really want to try static linking, this link might be of help http://software.intel.com/en-us/forums/showthread.php?t=64241
