Building TBB on Windows using MingW & Cmake
Refactor
Hey I'm trying to build TBB on my Windows computer using MinGW & CMake. (gcc,,g++, ..) I have already tried using the premade binaries but I keep getting undefined reference issues. My cmake for the project I'm trying to import it in looks as following:
find_package(TBB REQUIRED tbb)
target_link_libraries(projectName PRIVATE ${TBB_IMPORTED_TARGETS})
I use the source code of https://github.com/oneapi-src/oneTBB/releases/tag/v2021.3.0 (latest)
and I make a build dir and cd into it and execute:
cmake .. -G "MinGW Makefiles"
followed by: cmake --build . also tried: mingw32-make Both result into
[  1%] Building CXX object src/tbb/CMakeFiles/tbb.dir/address_waiter.cpp.obj
In file included from c:\users\refactor\downloads\onetbb-2021.3.0\onetbb-2021.3.0\include\oneapi\tbb\detail\_utils.h:26,
                 from C:\Users\Refactor\Downloads\oneTBB-2021.3.0\oneTBB-2021.3.0\src\tbb\address_waiter.cpp:17:
c:\users\refactor\downloads\onetbb-2021.3.0\onetbb-2021.3.0\include\oneapi\tbb\detail\_machine.h:67: error: ignoring '#pragma intrinsic ' [-Werror=unknown-pragmas]
   67 | #pragma intrinsic(_mm_mfence)
compilation terminated due to -Wfatal-errors.
cc1plus.exe: all warnings being treated as errors
mingw32-make[2]: *** [src\tbb\CMakeFiles\tbb.dir\build.make:76: src/tbb/CMakeFiles/tbb.dir/address_waiter.cpp.obj] Error 1
mingw32-make[1]: *** [CMakeFiles\Makefile2:454: src/tbb/CMakeFiles/tbb.dir/all] Error 2
mingw32-make: *** [makefile:165: all] Error 2```
NoorjahanSk_Intel
We are also able to reproduce the issue from our end. We are looking into it. We will get back to you soon.
Thanks & Regards
Noorjahan.
clevels
Hello, thank you for your ticket. I will also begin an investigation into this. Thanks!
clevels
Hello! Thank you for your patience. I have reviewed this issue and gone ahead nd filed a bug directly with the TBB development team and will provide an update just as soon as development reviews the issue. Thanks again.
clevels
The development team has reviewed this issue and it appears that MinGW support was added in oneTBB 2021.4 (https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-oneapi-threading-building-blocks-release-notes.html ).
we recommended trying sources https://github.com/oneapi-src/oneTBB/releases/tag/v2021.4.0 .
We don't currently test on MinGW relying on the community. If still there are some problems, let us know.
clevels
Hello- please let me know if you have any updates, otherwise I will be closing this issue. Thanks!
Peter_Parker
I tried with v2021.4.0 and latest using minGW64_810 .
v2021.4.0 configured using cmake and mingw32-make gave me:
mingw32-make
[ 0%] Building CXX object src/tbb/CMakeFiles/tbb.dir/address_waiter.cpp.obj
In file included from D:\dep\oneTBBsrc\src\tbb\concurrent_monitor_mutex.h:22,
from D:\dep\oneTBBsrc\src\tbb\concurrent_monitor.h:23,
from D:\dep\oneTBBsrc\src\tbb\address_waiter.cpp:19:
D:\dep\oneTBBsrc\src\tbb\semaphore.h: In member function 'void tbb::detail::r1::semaphore::init_semaphore(size_t)':
D:\dep\oneTBBsrc\src\tbb\semaphore.h:145:15: error: 'CreateSemaphoreEx' was not declared in this scope
sem = CreateSemaphoreEx( NULL, LONG(start_cnt_), max_semaphore_cnt, NULL, 0, SEMAPHORE_ALL_ACCESS );
mingw32-make[1]: *** [CMakeFiles\Makefile2:458: src/tbb/CMakeFiles/tbb.dir/all] Error 2
mingw32-make: *** [Makefile:165: all] Error 2
FlorentD
I also have the same problem when building oneTBB last version (2021.5.0) with CMake and GCC 9.2 :
$ mingw32-make.exe compiler=gcc arch=intel64
In file included from C:\build_oneTBB\oneapi-tbb-2021.5.0\src\tbb\concurrent_monitor_mutex.h:22,
from C:\build_oneTBB\oneapi-tbb-2021.5.0\src\tbb\concurrent_monitor.h:23,
from C:\build_oneTBB\oneapi-tbb-2021.5.0\src\tbb\address_waiter.cpp:19:
C:\build_oneTBB\oneapi-tbb-2021.5.0\src\tbb\semaphore.h: In member function 'void tbb::detail::r1::semaphore::init_semaphore(size_t)':
C:\build_oneTBB\oneapi-tbb-2021.5.0\src\tbb\semaphore.h:145:15: error: 'CreateSemaphoreEx' was not declared in this scope; did you mean 'CreateSemaphoreA'?
145 | sem = CreateSemaphoreEx( NULL, LONG(start_cnt_), max_semaphore_cnt, NULL, 0, SEMAPHORE_ALL_ACCESS );
| CreateSemaphoreA
What is wrong ?
