Hi all -
I wanted to package Intel-tbb for a Linux distro based on musl libc (instead of the normal glibc).
The compile fails because musl doesn't supply the mallinfo struct.
Has anybody been able to compile/use intel-tbb on a non-glibc Linux distro?
Thanks in advance!
-John
Are you using the malloc proxy (to replace all uses of malloc() etc. with TBB's scalable allocator)? If not, try changing "#define MALLOC_UNIXLIKE_OVERLOAD_ENABLED __linux__" to "#define MALLOC_UNIXLIKE_OVERLOAD_ENABLED 0" at or around src/tbbmalloc/proxy.h:24 (not tested).
