Is it possible to call scalable_malloc and scalable_free directly from tbbmalloc.dll instead of going through tbbmalloc_proxy.dll and the memory allocation function replacement stuff?
The reason I am asking is that I am running into the same issue in this post: http://software.intel.com/en-us/forums/showthread.php?t=70847&o=d&s=lr
My program crashes on exit, always in the doexit function (crt0dat.c):
I have a lot of static variables in my application, residing in many namespaces. Here is the TBB package that I used (I think it's 2.2 update 3):tbb22_013_win.exe
Package ID: w_tbb_pu_2.2.013
Version on tbbmalloc.dll:2.2.2010.204
TBB: VERSION 2.2
TBB: INTERFACE VERSION 4003
TBB: BUILD_DATE Thu, 4 Feb 2010 14:23:01 UTC
TBB: BUILD_HOST FXEOWIN16
TBB: BUILD_OS Microsoft Windows [Version 5.2.3790]
TBB: BUILD_CL Microsoft 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
TBB: BUILD_COMPILER Intel C++ Compiler Professional for applications running on IA-32, Version 11.1 Build 20090903 Package ID: w_cproc_p_11.1.046
TBB: BUILD_TARGET ia32
TBB: BUILD_COMMAND icl /nologo /Qvc9 /MD /O2 /Zi /EHsc /GR /Zc:forScope /Zc:wchar_t /Oy /DDO_ITT_NOTIFY /DUSE_WINTHREAD /D_CRT_SECURE_NO_DEPRECATE /D_WIN32_WINNT=0x0400 /D__TBB_BUILD=1 /W3 /WX
TBB: TBB_USE_DEBUG undefined
TBB: TBB_USE_ASSERT undefined
TBB: DO_ITT_NOTIFY 1
Thanks for you help.
-Long
Yes. You might also try replacing just C++ new/delete.
yes.
You can either look at implementation of proxy.h and link with tbbmalloc.lib library or use usual LoadLibrary calls.
--Vladimir
Yes :)
Include tbb/scalable_allocator.h, and link with tbbmalloc.lib. Or, as Vladimir suggested, load tbbmalloc.dll dynamically with LoadLibrary, and obtain function pointers with GetProcAddress.
BTW do you use tbbmalloc_proxy or modified implementaion? tbbmalloc_proxy should work with static variables and should not cause crash).
--Vladimir
It would be good to see if scalable_free and "A_B_C_KMEM_PUBLIC void operator delete" are on the stack. it looks that scalable_free is not called there.
--Vladimir
I was able to set a break point at scalable_free. What's funny is, the execution goes through both the if and the else clause, like they are not there.
A_B_C_KMEM_PUBLIC void operator delete (void *addr) {
//::operator delete(addr);
if (isRecognized(addr)) // I exposed this function
{ scalable_free(addr); } <-- this gets executed
else
{ ::operator delete(addr); } <-- then this gets executed
