Dear all,
I read the following example of concurrent_hash_map example(https://software.intel.com/zh-cn/node/506077) and this is fine:
parallel_for( blocked_range<string*>( Data, Data+N, 1000 ), Tally(table) );
Can the "Data" be a concurrent_hash_map type?
My requirement is that I have a concurrent_hash_map A, and a concurrent_hash_map B, how can I insert the entries in concurrent_hash_map A into the concurrent_hash_map B? I need to insert entries from concurrent_hash_maps into concurrent_hash_maps.
I write my code as follows:
40 struct MyHashCompare {
41 static size_t hash( const int& x ) {
42 return x;
43 }
44 //! True if strings are equal
45 static bool equal( const int& x, const int& y ) {
46 return x==y;
47 }
48 };
49 // A concurrent hash table that maps ints to ints.
50 typedef concurrent_hash_map<int,int,MyHashCompare> mapTable;
95 struct RULE{
96 mapTable rule_index;
97 mapTable word_index;
98 };
105 struct RULE* rule_full;
295 rule_full=new struct RULE[rules];
112 struct count4Rule{
113 mapTable& table;
114 count4Rule( mapTable& table_ ) : table(table_) {}
115 void operator()( const blocked_range<int*> range ) const {
116 //
117 }
118 };
181 parallel_for(blocked_range< mapTable::iterator >(rule_full[rulenum].word_index.range(),64), count4Rule((rule_full[rulenum].word_index)));
However, when I compile the code, I get the following error:
icpc -g -O3 -std=c++11 main.cc -pthread -ltbb
main.cc(181): error: no instance of constructor "tbb::blocked_range<Value>::blocked_range [with Value=tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<int, int, MyHashCompare, tbb::tbb_allocator<std::pair<int, int>>>, std::pair<const int, int>>]" matches the argument list
argument types are: (tbb::interface5::internal::hash_map_range<tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<int, int, MyHashCompare, tbb::tbb_allocator<std::pair<int, int>>>, std::pair<const int, int>>>)
parallel_for(blocked_range< mapTable::iterator >(rule_full[rulenum].word_index.range()), count4Rule((rule_full[rulenum].word_index)));
compilation aborted for main.cc (code 2)
make: *** [main] Error 2
What should I do? Any suggestions or example?
Feng
