Can TBB v4.x support Solaris?
zhaonaiy
Greetings,
From download page, it seems that TBB will not support solaris since version 4. Is that true?
Any response is very appreicated!!
Nai yan.
Vladimir_P_1234567890
Hi Nai yan,
TBB 4.0 and its updates support Solaris but binaries need to be built from sources like in mingw and other cases without precompiled binaries.
--Vladimir
RafSchietekat
Valued Contributor III
Please refer to the original "If TBB not support Solaris since version 4?" instead.
Hi Nai yan,
--Vladimir
zhaonaiy
Thank you so much!
- Nai Yan.
zhaonaiy
Thank you, Vladimir.
However, if Oracle Solaris Studio has any support for its compiling? Just want to make sure if there is any special configuration required for compling.
Thanks in advance!
Nai yan.
robert-reed
We don't have any special expertise to offer advice on the use of Solaris compilers, though perhaps there is someone in theIntel TBB user communitywho might know of any special hooks or support. We suggest that you try it and report any difficulties that you encounter.
