Can't build OSS TBB 4.3.2 for IOS
TVSori_N_
I downloaded TBB from https://www.threadingbuildingblocks.org and tried to build with "make target=ios arch=armv7", but got a lot of errors: (OS X 10.10, iOS SDK 8.1)
Created ./build/macos_armv7_clang_cc4.2.1_os10.10.1_release and ..._debug directories
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C "./build/macos_armv7_clang_cc4.2.1_os10.10.1_debug"  -r -f ../../build/Makefile.tbb cfg=debug
../../build/Makefile.tbb:31: CONFIG: cfg=debug arch=armv7 compiler=clang target=macos runtime=cc4.2.1_os10.10.1
clang++ -o concurrent_hash_map.o -c -MMD -g -O0 -DTBB_USE_DEBUG -DUSE_PTHREAD -fPIC -D__TBB_BUILD=1 -Wall -Wno-non-virtual-dtor -Wno-dangling-else    -I../../src -I../../src/rml/include -I../../include ../../src/tbb/concurrent_hash_map.cpp
In file included from ../../src/tbb/concurrent_hash_map.cpp:21:
In file included from ../../include/tbb/concurrent_hash_map.h:24:
In file included from ../../include/tbb/tbb_stddef.h:127:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h:64:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/stdint.h:52:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:32:
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/cdefs.h:680:2: error: Unsupported
      architecture
#error Unsupported architecture
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:33:
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/machine/_types.h:34:2: error:
      architecture not supported
#error architecture not supported
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:55:9: error: unknown type
      name '__int64_t'
typedef __int64_t       __darwin_blkcnt_t;      /* total blocks */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:56:9: error: unknown type
      name '__int32_t'
typedef __int32_t       __darwin_blksize_t;     /* preferred block size */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:57:9: error: unknown type
      name '__int32_t'
typedef __int32_t       __darwin_dev_t;         /* dev_t */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:60:9: error: unknown type
      name '__uint32_t'
typedef __uint32_t      __darwin_gid_t;         /* [???] process and group IDs */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:61:9: error: unknown type
      name '__uint32_t'
typedef __uint32_t      __darwin_id_t;          /* [XSI] pid_t, uid_t, or gid_t*/
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:62:9: error: unknown type
      name '__uint64_t'; did you mean 'uint64_t'?
typedef __uint64_t      __darwin_ino64_t;       /* [???] Used for 64 bit inodes */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/_types/_uint64_t.h:31:28: note:
      'uint64_t' declared here
typedef unsigned long long uint64_t;
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:68:9: error: unknown type
      name '__darwin_natural_t'
typedef __darwin_natural_t __darwin_mach_port_name_t; /* Used by mach */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:70:9: error: unknown type
      name '__uint16_t'
typedef __uint16_t      __darwin_mode_t;        /* [???] Some file attributes */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:71:9: error: unknown type
      name '__int64_t'
typedef __int64_t       __darwin_off_t;         /* [???] Used for file sizes */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:72:9: error: unknown type
      name '__int32_t'
typedef __int32_t       __darwin_pid_t;         /* [???] process and group IDs */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:73:9: error: unknown type
      name '__uint32_t'
typedef __uint32_t      __darwin_sigset_t;      /* [???] signal set */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:74:9: error: unknown type
      name '__int32_t'
typedef __int32_t       __darwin_suseconds_t;   /* [???] microseconds */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:75:9: error: unknown type
      name '__uint32_t'
typedef __uint32_t      __darwin_uid_t;         /* [???] user IDs */
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types.h:76:9: error: unknown type
      name '__uint32_t'
typedef __uint32_t      __darwin_useconds_t;    /* [???] microseconds */
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/stdint.h:53:
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types/_intptr_t.h:30:9: error:
      unknown type name '__darwin_intptr_t'
typedef __darwin_intptr_t       intptr_t;
In file included from ../../include/tbb/concurrent_hash_map.h:32:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/iterator:332:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/iosfwd:90:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/wchar.h:70:
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/_types.h:42:9: error: unknown type name
      '__uint32_t'
typedef __uint32_t      __darwin_wctype_t;
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/wchar.h:76:
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/sys/_types/_mbstate_t.h:31:9: error:
      unknown type name '__darwin_mbstate_t'; did you mean '__darwin_wctrans_t'?
typedef __darwin_mbstate_t mbstate_t;
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.1.sdk/usr/include/_types.h:40:14: note:
      '__darwin_wctrans_t' declared here
typedef int             __darwin_wctrans_t;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
make[1]: *** [concurrent_hash_map.o] Error 1
make: *** [tbb] Error 2
RafSchietekat
Valued Contributor III
Try again with the attached .zip extracted inside the tbb43_20141204oss/ directory (overwrites 3 files).
Already submitted as contribution (.patch with same content, forgot to mention Clang).
TVSori_N_
Thank you,
With that changes I sucessfully built iOS libraries.
贺_选_
hello,can you send me a library to me ,l am a student ,i really hurry to need it,thank very much!!
Peter_W_Intel
Here is a free software program for students.
balaji_c_
Hi all.
   I downloaded TBB from https://www.threadingbuildingblocks.org and tried to build for IOS/IPHONE with "make target=ios arch=armv7", but got a lot of errors:
I added the three  files said by Raf Schietekat
tbb43_20141204oss.Raf_Schietekat.iOS_.2015-01-03.zip
ld: building for OSX, but linking in object file built for iOS, file 'concurrent_hash_map.o' for architecture armv7
