2486 Discussions
Can use reference pointer of managed code in class of TBB?
anine
I have a problem. I want to use reference pointer(as array^) in parallel_for.
for example:
class ApplyFoo {
char *const my_a;
public:
void operator( )( const blocked_range& r ) const {
char *a = my_a;
for( size_t i=r.begin(); i!=r.end( ); ++i )
Foo(a);
ApplyFoo( char a[] ) :my_a(a){}
void ParallelApplyFoo( char a[], size_t n ) {
parallel_for(blocked_range(0,n,YouPickAGrainSize), ApplyFoo(a) );
I want to replace char* with array^. How should I do?
Dmitry_Vyukov
Valued Contributor I
Quoting - anine
There are several ways.
First is to use gcroot<> wrapper which is able to hold a reference to an object in managed heap. It uses InteropServices internally to accomplish this task.
[cpp]#include
class ApplyFoo
    gcroot a;
    ApplyFoo(array^ aa)
        a = aa;
[/cpp]
Dmitry_Vyukov
Quoting - Dmitriy V'jukov
[cpp]#include
class ApplyFoo
gcroot a;
ApplyFoo(array^ aa)
a = aa;
[/cpp]
S@#$! Syntaxhighlighter eats templates!
#include
class ApplyFoo
gcroot^> a;
ApplyFoo(array^ aa)
a = aa;
Dmitry_Vyukov
Second is to use GCHandle class. Here you have to manualy allocate and free references to managed objects:
using namespace System;
using namespace System::Runtime::InteropServices;
class ApplyFoo
IntPtr a;
ApplyFoo(array^ aa)
a = static_cast(GCHandle::Alloc(aa));
~ApplyFoo()
static_cast(a).Free();
void f()
array^ aa = safe_cast^>(static_cast(a).Target);
// use aa
Dmitry_Vyukov
Third is to 'pin' managed object. When you pin the object, you are able to get native pointer to it. While there is a live pin_ptr for object, it won't move in managed heap. Native pointer is valid only while pin_ptr exists.
struct ApplyFoo
char* a;
ApplyFoo(char* aa)
a = aa;
void operator () (tbb::blocked_range const& r) const {}
void ParallelApplyFoo(array^ a, size_t n)
pin_ptr aa = &a[0];
tbb::parallel_for(tbb::blocked_range(0, n, 1), ApplyFoo(aa));
AJ13
And what about standard C++? I checked online, having never heard of these constructs... they all seem to be MS creations outside the standard.
anine
Your answer has a lot of favor for me. Thank you for your help very much.
Dmitry_Vyukov
Quoting - AJ
Yes, these are MS creations outside standard. Exactly like objects in managed CLI heap themselves.
So we are talking here about so called C++/CLI, not ISO C++. Fortunately C++/CLI is a kind of superset of ISO C++, so TBB can be compiled as C++/CLI.
RafSchietekat
Valued Contributor III
I almost had a heart attack myself, so I propose that this stuff be properly flagged in advance (as "C++/CLI", not "managed code").
Dmitry_Vyukov
Quoting - Raf Schietekat
C++/CLI is exactly managed code, or ".NET" if you want.
Or more precisely, it's "ISO C++" + ".NET".
RafSchietekat
Anyone who knows that doesn't need to be warned anymore.
