2485 Discussions
Commercial-aligned and stable releases are being consolidated.
Vladimir_P_1234567890
You have probably noticed that several recent Intel Threading Building Blocks (Intel TBB) updates contain the same bits for commercial-aligned and stable releases. This was a consequence of reducing the release cycle time for commercial updates, causing commercial and commercial-aligned updates to appear more often.
We decided to consolidate the commercial-aligned and stable releases into a single, stable release starting with the next update. A new naming conversion will be available in the release timeframe, but we assume for now that it will be similar to that used by stable releases and there will be a comment explaining which Intel TBB commercial update corresponds to each stable version.
These changes do not affect our development releases: they will be available on demand as usual.
Any feedback is appreciated,
Intel TBB development team.
