Hi, Sirs, I met problems when compiling NDK within TBB over MAC platform.
May I ask you give me some advices? I want to know the root causes very much.
Thank you.
Error Messages:
[armeabi] Compile++ thumb: hello-jni <= hello-jni.cpp In file included from .../android-ndk-r9c/tbb42_20131118oss/include/tbb/tbb_exception.h:130:0, from .../android-ndk-r9c/tbb42_20131118oss/include/tbb/parallel_for.h:36, from jni/hello-jni.cpp:19: .../android-ndk-r9c/tbb42_20131118oss/include/tbb/tbb_allocator.h: In member function 'void tbb::tbb_allocator<T>::construct(U*, Args&& ...)': .../android-ndk-r9c/tbb42_20131118oss/include/tbb/tbb_allocator.h:130:30: error: 'forward' is not a member of 'std' .../android-ndk-r9c/tbb42_20131118oss/include/tbb/tbb_allocator.h:130:47: error: expected primary-expression before '>' token jni/hello-jni.cpp: At global scope:
Environemt: Android NDKr9c on MAC OS.
Related SW versions: tbb42_20131118oss.
Related Configuration
- Application.mk
APP_ABI := armeabi armeabi-v7a APP_STL := stlport_shared APP_GNUSTL_FORCE_CPP_FEATURES := exceptions rtti
- Android.mk
LOCAL_CFLAGS += -DTBB_USE_GCC_BUILTINS -std=c++11 -I$(TBB_PATH)/include
LOCAL_SHARED_LIBRARIES := -ltbb -L$(TBB_PATH)/build/macos_arm_gcc_android_cc4.6_NDKr9c_version_android-9_release
hello, could you try to change the c++ library?
APP_STL:=stlport_shared
to
APP_STL:=gnustl_shared
--Vladimir
First of all, I have to thank you, Vladimir.
I just tried Vladimir's comment.
- Application.m
APP_ABI := armeabi armeabi-v7a APP_STL := gnustl_shared APP_GNUSTL_FORCE_CPP_FEATURES := exceptions rtti
It shows another errors:
nb10080010:hello-jni Hawx$ pwd /Users/Hawx/sw/android/ndk/android-ndk-r9c/samples/hello-jni nb10080010:hello-jni Hawx$ ../../ndk-build Android NDK: WARNING: APP_PLATFORM android-19 is larger than android:minSdkVersion 3 in ./AndroidManifest.xml Android NDK: Trying to define local module 'gnustl_shared' in jni/Android.mk. Android NDK: But this module was already defined by /Users/Hawx/sw/android/ndk/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/Android.mk. /Users/Hawx/sw/android/ndk/android-ndk-r9c/build/core/build-module.mk:34: *** Android NDK: Aborting. . Stop.
Here is my jni/Android.mk configuration:
LOCAL_PATH := $(call my-dir) TBB_PATH := /Users/Hawx/sw/android/ndk/android-ndk-r9c/tbb42_20131118oss include $(CLEAR_VARS) LOCAL_MODULE := hello-jni LOCAL_SRC_FILES := hello-jni.cpp LOCAL_CFLAGS += -DTBB_USE_GCC_BUILTINS -std=c++11 -I$(TBB_PATH)/include LOCAL_SHARED_LIBRARIES := -ltbb-L$(TBB_PATH)/build/macos_arm_gcc_android_cc4.6_NDKr9c_version_android-9_release/ include $(BUILD_SHARED_LIBRARY) include $(CLEAR_VARS) LOCAL_MODULE := libtbb LOCAL_SRC_FILES := libtbb.so include $(PREBUILT_SHARED_LIBRARY) include $(CLEAR_VARS) LOCAL_MODULE := libgnustl_shared LOCAL_SRC_FILES := libgnustl_shared.so include $(PREBUILT_SHARED_LIBRARY)
I had similar problem. You need to remove lines 17-20 (libgnustl_shared stuff) from jni/Android.mk.
libgnustl_shared.so should be picked up by "APP_STL := gnustl_shared" clause in Application.mk and copied to the folder next to your hello-jni library. and do not forget to load libraries in correct order in the java code.
[java]
System.loadLibrary("gnustl_shared");
System.loadLibrary("tbb");
System.loadLibrary("hello-jni");
[/java]
BTW our latest development release contains tachyon example (<root>\examples\parallel_for\tachyon\android) that can be built for all architectures and it should show the path where it expects to see architecture-specific libtbb.so library.
--Vladimir
And BTW, there is a tutorial how to create apps with intel tbb library for android.
--Vladimir
