Compiling TBB with Android NDK r9c in Windows 7
Alex_H_
My working platform:
WIndows 7 + Android NDK r9c + Cygwin installed
I download Intel TBB (tbb42_20131118oss), and trying to compile it for arm/x86, what I did is
in Windows command box, change to the top-level directory of Intel TBB source tree, then give the command
ndk-build target=android tbb
The error I got are:
src/Makefile:29: ../build common.inc: No such file or directory
c:/android/android-ndk-r9c/build/core/build-all.mk:89: Android NDK: WARNING: There are no modules to build in this project!
make.exe: *** No rule to make target '../build/common.inc'. Stop.
in TBB source tree, .\build\index.html, it seems that it is for Linux?
Should I build TBB for Android only in Linux box, or anything I did wrong?
Alex
Vladimir_P_1234567890
Hello, try  the follwing command
ndk-build target=android tbb -C c:\program_code\tbb42_20131118oss\jni tbb_os=windows
ndk-build needs to be run from jni folder in this case.
--Vladimir
Somehow it did not recognize that this is a windows build.
pls try the following command
ndk-build target=android tbb tbb_os=windows
--Vladimir
Alex_H_
Hi Valdimir,
Thanks for reply. I tried your solution, but still no luck. I append a "-d" flag in my command line
Here the output with this command line
ndk-build target=android tbb -C c:\program_code\tbb42_20131118oss -d tbb_os=windows
the output is attached to this message, seems that it always working with ../src/Makefile, but not the top-level Makefile, is that the problem? Thanks for your time.
Alex
Alex_H_
Hi Valdimir,
I finally gave up in Windows 7, and turn to Ubuntu box. The first tries still failed, so I tried to get into ".\src" folder, then run ndk-build, this time, everything just goes well. Not yet tested these binary files in Android App, will tried later.
I still got one question is, anything I did wrong in Windows platform? or, you suggest that we do this compilation in Linux in the future?
In Windows 7, I tested several other way, the only way I can get a bit closer is:
1. use bash shell
2. enter ".\src" folder of tbb source tree
3. run command line
4. it starts compiling, but complaining a lot of file (header files) missing, for example "../../include/tbb/tbb_staddef.h"
also, there is an error that says
getconf: Unrecognized variable 'GNU_LIBC_VERSION'
maybe that is the problem in windows that can not find gcc
--Vladimir
Alex_H_
Hi Vladimir,
That was it. I can make it in Windows 7 in the way you provide. x86 and arm are fine.
Thank you very much.
Alex
Great, we'll try to add more diagnostics to android makefile files.
--Vladimir
