Computing Pi - how to use lambda expression
mikajlo_m_
Hi, every one.
I want to calculate PI using multi-core parallel algorithms. I have following code:
It seems to work well, but I can't write this with lambda expression.I tried to use example from this topic, but still something is wrong.. Please, show me how it could be look like..
[cpp]
#include <stdio.h>
#include <tbb/blocked_range.h>
#include <tbb/parallel_reduce.h>
#include <tbb/task_scheduler_init.h>
class Pi_MC
private:
    long num_steps;
    double step;
public:
    double pi;
    void operator () (const tbb::blocked_range<long> &r)
        double x, sum = 0.0;
        long end = r.end();
        for (int i = r.begin(); i != end; i++)
            x = (i - 0.5) * step;
            sum = sum + 4.0 / (1.0 + x*x);
        pi += sum * step;
    void join(Pi_MC &p)
        pi += p.pi;
    Pi_MC(Pi_MC &p, tbb::split)
        pi = 0.0;
        num_steps = p.num_steps;
        step = p.step;
    Pi_MC(long n)
        pi = 0.0;
        num_steps = n;
        step = 1.0 / (double) num_steps;
int main()
    tbb::task_scheduler_init init;
    const long n = 100000000;
    Pi_MC pi(n);
    tbb::parallel_reduce(tbb::blocked_range<long>(0, n, 1000000), pi);
    printf ("Pi = %.16f steps: %d \n", pi.pi, n);
    system("pause");
[/cpp]
RafSchietekat
Black Belt
Something like this perhaps (not tested): [cpp] #include <stdio.h> #include <functional> #include <tbb/blocked_range.h> #include <tbb/parallel_reduce.h> int main() { const long num_steps = 100000000; const double step = 1.0 / num_steps; const double result = tbb::parallel_reduce( tbb::blocked_range<long>(0, num_steps), 0.0, [] (const tbb::blocked_range<long> &r, const double value) -> double { double sum = 0.0; for (int i = r.begin(), end = r.end(); i != end; i++) { const double x = (i - 0.5) * step; sum += 4.0 / (1.0 + x*x); } return value + sum * step; }, std::plus<double>() ); printf ("Pi = %.16f steps: %d n", result, num_steps); system("pause"); } [/cpp] Edited on 2013-01-02, after next 3 postings: added missing "#include <functional>", and another self-indulgent "const" with the "value" parameter ("const" should have been the default all along, and "var" should have been an additional keyword...).
mikajlo_m_
This code didn't want to be accepted: [cpp] std::plus() [/cpp] replaced it: [cpp] []( double s1, double s2 ) { return s1+s2; } [/cpp] and Viola! Happy 2013!
RafSchietekat
Black Belt
Did you use "#include <functional>"? I'll assume that the template argument failed to show up because you wrote "std::plus<double>()" instead of the workaround syntax "std::plus&lt;double&gt;()" to assure correct visualisation in this forum.
mikajlo_m_
I didnt have include.. Works! ;)
RafSchietekat
Black Belt
Now for a finishing touch: does the following work instead of that for loop to determine "sum" (with "#include <numeric>", of course)? [cpp] const double sum = std::accumulate(r.begin(), r.end(), 0.0, [] (const double acc, const long i) -> double { const double x = (i - 0.5) * step; return acc + 4.0 / (1.0 + x*x); }); [/cpp] Actually using that might be a bit pedantic, though, as it doesn't really make the code more concise... although perhaps it does illustrate intent a little bit better. It could also be interesting to compare timing results, because it seems more challenging to optimise around that lambda than with a straightforward loop.
mikajlo_m_
Ok, thx for advice!
