2485 Discussions
Concurrent hash map. Problems with accessor and iterator
Adri_C__S_
I was trying to make a class HashArray, which will act as an "envelope" for the tbb::concurrent_hash_map.
However, I have problems with the accessor and the iterators of the concurrent map.
It seems that the accessors in DoSomething() are not recognised, as well as the iterator in GatherStats().
Here's the code:
[cpp]#ifndef TBB_HashArray_h
#define TBB_HashArray_h
#include "tbb/concurrent_hash_map.h"
#include
namespace mcl {
template
struct HashCompare {
static size_t hash( const K& key ) {
return tbb::tbb_hasher(key);
static bool equal( const K& key1, const K& key2 ) {
return ( key1 == key2 );
template
class HashArray {
private:
static unsigned int initial_hash_size;
tbb::concurrent_hash_map > h;
HashArray(const HashArray& S);
const HashArray& operator=(const HashArray& S);
public:
HashArray(): h(initial_hash_size) {}
~HashArray() {}
bool DoSomething(const K& key) {
tbb::concurrent_hash_map >::accessor a;
h.insert(a,key);
return true;
const bool DoSomething (const K& key) const {
tbb::concurrent_hash_map >::const_accessor a;
h.insert(a,key);
return true;
bool IsDefined(const K key) const { return h.count(key)!=0; }
void UnDefine(const K key) { h.erase(key); }
void GatherStats() const {
tbb::concurrent_hash_map >::const_iterator it = h.begin();
while ( it != h.end() ) {
//std::cout << ((*it).second).size() << std::endl;
++it;
void Clear(void) { h.clear(); }
void Resize(void) { h.clear(); }
template
unsigned int HashArray::initial_hash_size=1000;
#endif[/cpp]
Thanks!
Adri_C__S_
Hi again,
it seems that the problem is the use of templates. If I use
tbb::concurrent_hash_map>::accessor a
when compiling I get an error:
error: expected `;' before a
However, if for example I write
tbb::concurrent_hash_map<:STRING>>::accessor a
when compiling that error disappears.
But I need to use templates... any idea? I'm in blank.
Thanks!
Ilnar
try to write:
tbb::template concurrent_hash_map>::const_accessora;
or
or
typename tbb::template concurrent_hash_map>::const_accessora;
or
Adri_C__S_
Yes. It worked well with typename.
Thanks ilnarb.
