2455 Discussions
Debug build for sub_string_finder example exits without error
stavitsky__joseph
Howdy folks. I built examples\sub_string_finder and release build produces expected output, but debug build quits to commandline without error. Does it need to have the debugger attached or something?
Platform: Win10 x64 v1809 on AMD A12
Compiler: VS2017
Many thanks in advance for any help
Joe
Alexei_K_Intel
Is tbb_debug.dll available in the environment (%PATH%)? Do you use Visual Studio solution file or command line?
